Chassis number 'decoder' and GPS antenna
- 1.8 8v
Hi,
I've purchased a used '04 406 2.0 HDi stw. However I would like to know exactly which motor, equipment and 'features' (like antispin etc) this vehicle was equipped with originally.
Would this be possible to find this out off the chassis number? Does it exists tables or data to find such data on the Net?
Also, my car is not equipped with Navigation. However I would like to mount a GPS, and I wonder if there is a Navi antenna prefit somewhere (in the windscreen?) Any comments on this (and where / how to mount and exteranal GPS antenna if there is no other solution...)
regards
Tor
regards
Tor
- mjb
Re: Chassis number 'decoder' and GPS antenna
http://public.servicebox.peugeot.com
Register (it's free) then go to 'spare parts', put your vin in and go to 'characteristics'
- Site Admin & Mad Biker!
In answer to your first question, go ServiceBox, register for a free account and you can type in your VIN number and find out everything you wanted to know!
Edit: Damn, you beat me mjb
Your plug arrived yet?
- mjb
Let you know when I get home from work...teamster1975 wrote:Your plug arrived yet?
What happened to the days when you could get your post in the morning?
- 1.8 8v
Great, I will register and check. Thanks for the tip!
What about any GPS antenna tip...?
Tor
Tor
- mjb
woot!mjb wrote:Let you know when I get home from work...teamster1975 wrote:Your plug arrived yet?
Anyone know what ECU pin it's on for the Bosch MP7?
Thank god for thatmjb wrote:woot!mjb wrote:Let you know when I get home from work...teamster1975 wrote:Your plug arrived yet?Guess what I'm up to tomorrow morning?
Yep, trying to find wire 1368 and then trying to find a way of getting it behind the dashboard...
- mjb
Yeah I figured that bit outteamster1975 wrote:Thank god for thatThe royal mail can be trusted sometimes! All the leads are in the correct place to be wired straight in, the connector will slot into the existing one.
The boggling thing though is the numbering on the wires - wtf did you rip this out of? It can't have been a 406!
I'll let you into a secret, I made it up myself, copied my one so you didn't have to piss about. The wires are odds and sods I had left over when I wired the leccy rear windows into my LX, may it rest in peacemjb wrote:The boggling thing though is the numbering on the wires - wtf did you rip this out of? It can't have been a 406!
You owe me a beer or two should our paths ever cross
- 1.8 8v
Anyone knowing if a '04 406 station wagon despite lack of fitted navigation has a gps antenna (in the windscreen) with cable to use with a non-original gps unit?
If yes, where do I find (the plug end of ) the cable...?
Thanks for any hints on this issue
regards
Tor
regards
Tor
