need more boost
lawsys406t
need more boost
Post by lawsys406t »
hey all seen few bits about pulsar/200sx turbo t28? i think fiting straight on my tubby. if this is right with a stand alone management what sort of bhp and psi of boost will she run? would i need to do anything else? hhhheeelllpppp 8)
lawsys406t
Re: need more boost
nobody know then? :shock:
niz406
Admin <BR>Turbo God
Re: need more boost
Post by niz406 »
No it is not right, the exhasut housing ( Although if the turbine trim is the same as the T28 you may be able to simply swap the exhaust housings ) is wrong and so are the hose connectors... the T28's of those cars have 3 bolt flange connectors with gaskets... the 406 turbo has push fit hose connectors, another problem might be space... there is not much room for larger turbo's behind the engine... just crawl in and have a look see! ! The T28 uses a .48 A/R compressor cover, the 406 uses a .42 A/R and then comes the mounting point of the actuator, this would have to be addressed too!
Stock turbo will take 12 - 13 psi all day long with regular oil changes, standard electronic boost control on the 406 maxes out at about 12 p.s.i, so the choice is to either hybrid your standard turbo with a T28 wheel ( like I did ) or buy an aftermarket exhaust manifold and downpipe etc. then you can bolt any turbo you want to it ! !
Sort the turbo / intercooler combo, have it remapped / chipped, introduce a higher rated fuel pump and adjustable pressure regulator and you will be good for 220 - 250 providing you address the exhaust system!
Niz406
lawsys406t
Re: need more boost
thanks mate. sent for a quote from pug1off. using tubby engine that they put in to 205 they offer standard 150 or a deal with bigger turbo,injectors and cutom map for 250bhp. hows your tubby it looks sweet and simple like mine. what bhp you pushin at what psi with your turbo mate 8)
