Airbag Warning light
- Newbie
Read all the threads on here now refering to Airbag failures and it seems apparent that the Airbag warning light flashes to determine the actual fault. 1.. Permanantly on
2.. On for 5 seconds then flashes
3.. flashes
Can anyone tell me the actual fault allocated to each warning description
3.. flashes
Re: Airbag Warning light
I dunno about any of the others but on my D8 the constant flashing was the airbag ecu.
(Well, either that or it was something much simpler but Pug charged me for changing the ecu...)
On mine it flashes when the under seat connections are playing up and it's permanently on if you disable it via the key near the handbrake (I tried that once).
- Newbie
Cheers for the reply,
I'm left with three options, ignore it (as it's not an MOT fail) cut and solder seat airbag/pretensioner harness (which you have to cut and solder again if you have to take the seat out for anything) or replace the comm2000, which, is looking favourite as the indicator stalk is faulty.
- Newbie
Air bag light still on, indicator stalk an absolute nightmare and now the horn doesn't work, can't see how it can be anything other than the comms 2000
- Site Admin & Mad Biker!
Steady on supa!
Picked my 406 estate up today and first off the sat nav stopped working now airbag defective light coming on any ideas and what is comm 2000 ?
cheers
Steve
cheers
Steve
- DaiRees
Airbag light is probably connectors under the seats, and sat nav unit needs a clean (I answered that in the other thread).
Loads of info on here mate, try a search on both topics.
Dai Rees,
cheers mate checked under seats and connections must have been problem in past they have some electrical tape on them just gave them a bit of a squeeze and airbag light gone off. No joy with satnav have cleaned disc and unit
Comm2000 infosteveyleyland wrote:any ideas and what is comm 2000 ?
