What have you fixed or replaced on your 406?
I've never seen this topic posted, thought it would be interesting to see what we've all had to fix! :shock:
I've done (in no particular order)
Rear discs, pads and handbrake shoes
Handbrake cables
New radiator, top hose and bottom hose
New thermostat & seal
New alternator and Aux belt
New front and rear antirollbar drop links and bushes
New top strut bearings
New rear top links
New top engine mount
New middle and rear exhaust sections
New dip stick (!!)
New rad fan
New airbox & airfilter
New plugs and leads
New throttle linkage
There's probably more but that'll do for now!
Re: What have you fixed or replaced on you 406?
EGR Valve
Some sensor that I don't actually think was faulty
3 Sets of plugs, all of which turned out to still be OK
Front discs and pads
Wipers, oil & filters, tyres etc...
That can't be right... there must be more!! :o
Edit1: Stainless exhaust fitted. :oops:
jasper5
Post by jasper5 »
Rubber mounting blocks for the engine cover.
Heater control module.
Drivers side window switch assembly.
Exhaust system.
Timing belt kit.
Alternator belt.
Rear pads.
Engine management coolant sensor.
Various service related items.
Car is due for service and mot next week, so, list may grow :frown:
Re: What have you fixed or replaced on your 406?
Oh dear...
New gearbox
New clutch + Machined flywheel + Thrust bearing
Top engine mount
New discs + pads x4
Timing Belt + Waterpump + Tensioners
Gear linkages
Fuel Filter
Pollen Filter
Oil Filter
Air Filter
Tyres
Probably more I can't think of at the moment - Just don't look at the bills :P
eoin27
The Irish 406 addict
Post by eoin27 »
New 406
Lower Engine Mount
Old 406
Wiper Stalk
Indicator Stalk
Rear Drum Overhaul
High Pressure Fuel Pipe
Low pressure fuel pump overhaul
Airbag Rewiring
Handbrake Cable
Timing belt kit and water pump ......... but it had already been done :oops: :roll:
Bottom pulley ......... but it had already been done :oops: :roll:
blower fan ......... it was the ignition switch :evil:
ignition switch .......... :oops:
Air Dozer .......... old one just came apart but with a tie wrap around it still works :P
discs pads shoes all round .......... routine :)
LP pump
And now the bad bit because so called fooking experts didn't know what the fook they were doing :evil:
Condensor
a/c pipework
a/c compressor
condensor pressure switch ......... the original problem that i discovered was leaking after all the muppets had failed :evil:
several re-gasses
And now, the end is near...
I replaced my D8 with a D9 and I'm still driving the D8 :shock:
And so I face the final curtain...
But today I was looking at it and I noticed a hole in the passenger side sill under the B-post :shock: :shock:
You cnut, I'm not a queer...
So I investigated and noticed the paint bubbling further along, so I pulled that off and there was another hole :shock: :shock: :shock:
I'll state my case of which I'm certain...
It's fold-up-a-tastic! :(
Ok, D8:
both rad fan's brushes
rear wash/wipe was siezed when I got it
headlamps were loose when I got it
clutch
timing belt, aux belt water pump etc.
front springs, top bearings and shocks
speedo fag box thing
air bag ecu
front arb drop links, twice
driver's seat repaired
cat
rear disks
gearbox noisyness/argumentativeness
that bluddy pipe :x
plus the usual service stuff a few times
D9:
timing belt, aux belt, water pump, crank pulley etc.
rear disks (well, ok, I nicked them off the D8 :cheesy: )
rear tie rod fingies
air con thingy in o/h console
1 rear caliper sliding pin
(I bet I forgot loads)
Front pads & exhaust back box for MOT
After 1 side lamp & 1 number plate lamp went, swapped them all for quad-led lamps.
(aircon still to fix)
Previous Xsara:
Battery, Timing belt & water pump, Bottom pulley, Air bag re-wire, Rear exhaust
Wiring loom repair to restore power to LP pump
Timing belt again, Bottom puley again, plus aux drive belt, tensioners etc.
Front discs, 3 sets of front pads, 1 set rears
5 H4 headlamp bulbs
Countless 501 side / number plate lamps - changed them in pairs after the first year or so.
Normal service bitz, 7 tyres.
(still reckon this was brilliant for 4 yrs/100k miles with only 1 breakdown - hope the 406 does as well)
StevieboyTD
Post by StevieboyTD »
So far...
Cambelt and tensioners, waterpump, aux belt (can't afford the tensioner on that one!)
Glowplugs
Turbo & inlet (only need turbo, but i did both so i could ditch the EGR crap.
2.1td exec estate.
I've replaced the wheels and the ICE head unit.
No other changes or repairs have been needed in the 4 months I've had the car - long may that continue.
Just passed the 33,000 mile mark today 8)
madbaggie28
Post by madbaggie28 »
various tyres
wiper blades
about 6 head light bulbs ??????
various service parts (oil filter air filter)
heater control module
new leather seats
rear pads
and thats it but just passed another mot that is 4 passes now but was advised to change front discs and pads
Since buying it just a month ago:
Top engine mount
Clutch slave cylinder
Brake fluid changed+bled
Drivers wiper blade replaced with a Valeo flat one
Washer jets replaced with Citroen mist ones
Partial fix on a noisy overhead temperature sensor fan
Bulbs
Air filter
Pollen filter
Put my JCV stereo in
Front spark plugs (rears today with luck)
Rear brake pads (today with luck)
There's a lot more to come :cry:
TooT
Post by TooT »
I replaced -
4x Tyres
1x Middle section exhaust
1x Exhaust back box
2x Rear anti roll bar bushes
Thats all it needed in 2.5 years :shock:
totaleclipse
Post by totaleclipse »
timing belt
rocker arm
adjusted handbrake cable
fitted new pads on rear
serviced rear calipers
electric window switch
electric mirror switch
electric passenger seat switch
replaced a burnt out wire on the climate control
had a rattle on the exhaust repaired 3 times (its rattling again)
replaced rear driver side door and resprayed driver side of car
changed number plate bulbs
front near side wheelbearing replaced.
fitted a towbar
all in the last 7 months, but the car was only £250.............
1997 2.1TD executive estate - mmmm, lovely :)
bigdaves406
Post by bigdaves406 »
top engine mount
fuel pipe
exhaust from cat back
side light bulb
bulb for the clock
all in the last mouth
