Cruise Blues
Cruise Blues
Mine's just died on the way home :cry:
Working fine on the A14, switched back on after the roundabouts and nothing.
Tried fiddling with brake & clutch pedals, selector switch on & off etc, tried 4th too, nothing.
Any ideas people :?:
Re: Cruise Blues
First thing to check is the switches on the brake and clutch pedals. Careful not to mess up the brake light switch like I did :oops:
Check the fuse too
Re: Cruise Blues
mjb wrote:First thing to check is the switches on the brake and clutch pedals. Careful not to mess up the brake light switch like I did :oops:
Check the fuse too
Had a look at BoL - looks like the same fuse for stop lights & c.c. & it appears to have two switches on the brake pedal :frown: Can't be sure cos mine hasn't got all the petrol c.c. gubbins......
Re: Cruise Blues
dogslife wrote:Had a look at BoL - looks like the same fuse for stop lights & c.c. & it appears to have two switches on the brake pedal :frown: Can't be sure cos mine hasn't got all the petrol c.c. gubbins......
One of the brake pedal switches is for the cc, the other is for the brake lights
Re: Cruise Blues
Thanks for the suggestions, Matt - I'll try it tomorrow.
djp30djp
2.2 16v
Re: Cruise Blues
Post by djp30djp »
The clutch switch on one of mine had a habit of popping out of the bracket but some superglue fixed it
406 HDI Exec Estate (2 off) & 307CC HDI Cabriolet
Re: Cruise Blues
Sorted! 8)
Just decided to work today, though I'm now thinking a bit of dust in the stalk, as it failed to respond to the increase/set button at least once.....
Looks like the approved technique for 406 electronic gremlins should be 'leave it in the garage overnight' :shock:
(Cured the Anti-Pollution Fault too).
Re: Cruise Blues
Can you actually use the 'Cruze' and relax with it though?
Every time I try it some other motorist ruins my 'cruise space'.
I find it worse than driving with your foot on the pedal for sure.
Re: Cruise Blues
I must say, I don't particularly like the cruise control on the '6. When maintaining speed, it *seems* to be quickly alterternating between full throttle and no throttle. My crappy Honda used to do it in quite a smooth fashion...
Could be just perception, though... :?
Re: Cruise Blues
I asked the Volvo to 'resume' to 80mph in 3rd and it went for it :shock:
It did it in a steady way though, but I was surprised. Might try 2nd gear tonight :twisted:
Generally though I wouldn't say I really use the cruuuze..
eoin27
The Irish 406 addict
Re: Cruise Blues
Post by eoin27 »
I wouldn't mind the radar controlled Cruise Control available in Merc S-Classes!!
Re: Cruise Blues
Captain Jack wrote:I must say, I don't particularly like the cruise control on the '6. When maintaining speed, it *seems* to be quickly alterternating between full throttle and no throttle. My crappy Honda used to do it in quite a smooth fashion...
My ES9J4 saloon was very smooth working the pedal... when the cruise worked...
The coupe, forget it. It's on the todo list to fix :cry:
Re: Cruise Blues
I love crooze, use it every day without exception. :D
You really have to adapt your driving style (and maybe your attitude too) to get the best out of it though. :wink:
Re: Cruise Blues
I'm with Dai on this one, use it every day, one of the reasons I choose this car.
Re: Cruise Blues
Well, tried a 'resume' to 60 in second this morning and it went for it again :shock: :lol:
...quickly followed by the 'off' button :|
