Welton wrote:Nurse that clutch baby, Nurse it
You won't believe just how smooth my driving is at the moment, especially the downshifts where I'm double-declutching everything and managing to get over 95% of shifts
perfectly rev-matched
Tis a brave man who changeth the clutch of a V6 in one's garage with nothing more than an axle stand and a Halford's Gift Voucher
What gift voucher?
If I run out of tools or botching ability, it's going to be sat there for a month until I get paid
Have you got a definitive how-to?
Nope, what I *think* I'm going to try to do is:
remove the clutch slave cylinder, hopefully without detaching the pipework
remove the air filter box, gear linkage, reverse switch connector (slackening the switch), crack the gearbox mount
shove it on axle stands
remove the undertray
empty the oil
remove the wheels
undo the lower balljoints on the wheel hub carriers and use a crowbar(???)(need to buy) to lever off?
pull the the wheel hubs off the driveshafts
pull the driveshafts out of the gearbox
remove the speed sensor
change the lower engine mount
change the CV boots
support the gearbox
remove the gearbox mount
remove the gearbox->engine bolts (i have no idea about these)
drop the gearbox out
unbolt the clutch plates, discard
remove the thrust bearing parts, discard
then the opposite of all the above
All that of course is 100% guesswork. I have very little idea what I'm supposed to be doing
I can see myself ending up with a pile of oily cogs falling on my head... I mean, there's so much I have no clue about, like how to dismantle the lower steering balljoints and put them back, or how to undo/redo the clutch plate from the flywheel when the flywheel's going to want to turn?!? or how to change the cv boots, or what grease to use where, and ARGH!
I'm sh*tting bricks over this job, but every penny counts for the next 2 months
