Hi all,
Yesterday I did the cambelt on my 2.0 16v 406... When I tried to time up the bottom pulley the outer part of the pulley has moved causing the timing hole to be in the wrong place when the cams are timed up. The rubber has perished sightly, what is the chances of the outer part of the pulley coming off the inner part?
I also replaced the waterpump at the same time as the one fitted was noisy. Now ive got a different noise, sounds a bit like a bearing... hard to describe. I replaced all the idler pully and tensioner so there isn't anything that could be causing a problem.... Any ideas? Bottom pulley catching the cover?
Thanks,
Dan
Bottom pulley & cambelt change
- Captain Jack
Re: Bottom pulley & cambelt change
Do you get the same noise with aux belt off?
- Site Admin & Mad Biker!
Silly question, are you certain that the new pump is ok?Pob wrote:I also replaced the waterpump at the same time as the one fitted was noisy. Now ive got a different noise, sounds a bit like a bearing... hard to describe.
Don't say that! It's perfectly fine... It's staying on and thats final
It just felt like a new water pump before fitting, felt a little tight like they do, no play in the shaft... seemed ok to me
Dan
Dan
