Roof Lighting console
- Newbie
I have just replaced my cars Ariel, can anyone tell me what looks like a little fan is, that is in the roof lighting console of my D8 2.1 td glx estate, it is situated next to the map light ?
. Can not find any reference to it in the owners or Haynes manuals, all help gratefully received.
- Leopold
Re: Roof Lighting console
Could it be something to do with the sunroof? If you have the electric Sunroof, it as a emergency handle if it fails to close or open you insert the handle into it? Just anhawkeye357 wrote:I have just replaced my cars Ariel, can anyone tell me what looks like a little fan is, that is in the roof lighting console of my D8 2.1 td glx estate, it is situated next to the map light ?. Can not find any reference to it in the owners or Haynes manuals, all help gratefully received.
'99 Peugeot 406 1.8 16v LS in Jade Green
Cabin air temp sensor for the climate (there are 2 apparently).
Steve is right it's a 'sample' fan pulling a sample of cabin air across a sensor to give readings back to the climate ECU with regards to the main fan speed and temperature control. The other sensor is a sunlight intensity sensor at the bottom of the windscreen (dash).
They do get caked up after a few years so worth cleaning it - this action can also revive a seized one too!
DOn't break it tho, the bearings must be rubies, judging by the amount Pug charge for a new one
- Newbie
Cheers guys, i did wonder if it was something to do with the a/c, gave it a good clean down i don't think it had been touched for years the cab was like it had a dust storm inside it. Thanks again for the help
