petrol tubby problem
nigelw
Re: petrol tubby problem
Post by nigelw »
you maybe right i just had a look at my 406 V6 and that doesn't have a MAF i know the diesels do and most petrol models so no need to go hunting for something that may not be there
406 3.0 V6 saloon
The XU10J2TE tubby and ES9J4 v6 (maybe the early XU10J4 16v?) don't have MAFs. The ES9J4 has a MAP sensor poking out the back of the inlet manifold.
The XU10J2TE has a MAP sensor built into the engine ECU (Bosch MP3.2) itself which is fed from a small pipe on the throttle body which goes into the engine wiring harness and plugs into the ECU.
mjcook1984
Post by mjcook1984 »
mjb wrote: The XU10J2TE has a MAP sensor built into the engine ECU (Bosch MP3.2) itself which is fed from a small pipe on the throttle body which goes into the engine wiring harness and plugs into the ECU.
now mine does have that. thanks for putting my mind at ease mjb
SRI 306 project On Hold Due to Baby and Missus sucking my wallet dry
ddoherty406
Post by ddoherty406 »
Is the maf not part of the throttle body like in the 2.0 16v? On my 97 There was a wee diode looking thing, just like the inside of the tube type maf. When you take the air intake off the throttle body its just inside if i mind right.
ddoherty406 wrote:Is the maf not part of the throttle body like in the 2.0 16v? On my 97 There was a wee diode looking thing, just like the inside of the tube type maf. When you take the air intake off the throttle body its just inside if i mind right.
IIRC there's a heater element (big yellow thing) to the top left, a temperature sensor to the top right, and the throttle pot on the right side
