Anyone know if the 2.2hdi estate back box is the same as a 2.0hdi estate back box?
or other model for that matter?
thanks in advance!
2.2hdi estate exhaust back box
Cambs
2001 2.2HDI Estate
2001 2.2HDI Estate
Re: 2.2hdi estate exhaust back box
According to ServiceBox & most pattern suupliers, no - they're different. (They look the same, so it's hard to see what difference there could be). ServiceBox DOES list the same one for 2.2's and 2.0 HDi 110's with particle filter, but it's doubtful whether any of these cars really exist.
I got an OE one from http://www.thepeugeotshop.co.uk/ on special offer for about £95 delivered, figuring that the original had lasted 7 years, so this would see it out. The other end of the scale is http://www.onlineautomotive.co.uk/ who do one for about £33, but expect to do it again in a year or two. Some on eBay too.
i think the diffrence is in the diamanter of the exhaust pipe as all the mounts can be swappeddogslife wrote:According to ServiceBox & most pattern suupliers, no - they're different. (They look the same, so it's hard to see what difference there could be). ServiceBox DOES list the same one for 2.2's and 2.0 HDi 110's with particle filter, but it's doubtful whether any of these cars really exist.
Yep! HDi 110 = 74.5mm clamp, Hdi 136 = 66mmomega wrote:i think the diffrence is in the diamanter of the exhaust pipe as all the mounts can be swapped
dont no where you got that info from but do you know what the 2.1 dt is ? tadogslife wrote:Yep! HDi 110 = 74.5mm clamp, Hdi 136 = 66mmomega wrote:i think the diffrence is in the diamanter of the exhaust pipe as all the mounts can be swapped- now make sense of that!
3 = 1713 69 FIXING CLAMP DIAM 74,5 - TURBO DIESEL XUD11BTE AND ESTATE
4 = 1726 AN REAR SILENCER - TURBO DIESEL XUD11BTE AND ESTATE
thanks for the info guys, and for the site links omega.
looks like after market parts have the second bracket welded to the side of the muffler, where as OE looks like the bracket is a band around it. Like you say omega, one will last a couple of years....
Cambs
2001 2.2HDI Estate
2001 2.2HDI Estate
- Captain Jack
Or you could go all offensive with the stainless steel one which will outlast the car.
