Knock on front
Will406td
Knock on front
Post by Will406td »
Hey all
in need of advice again
have a clunk coming from the front when I accelerate
it's not a cv joint cuz it's not a clicking all the time. It's just one clunk
when I pull away
any advice would be brilliant cuz the clunk is doing my head in.
Silver 406 GLX 2.1TD saloon
mandelbug
Re: Knock on front
Post by mandelbug »
Anti roll bar drop links starting to go? Sounds like it might be a case of get it in the air and have a good shake/tap with a mallet of things
HimBigChief
Re: Knock on front
Post by HimBigChief »
Engine mount?
Image Image
Re: Knock on front
Does sound like top engine mount.
poddack
Re: Knock on front
Post by poddack »
Mine did recently, top engine mount replaced, no bonk!
Hmmmm, straight 6 goodness!
Will406td
Re: Knock on front
Post by Will406td »
Put it up on the ramp at work. Poked and proded. Found slight play in o/s trackrod end.
The O/s droplink is abit suspect so I changed both trackrod ends and droplinks. Car feels
alot better but clunk still there so will change top mount.
Thankyou so much for your help
much appreicated.
Will406td
Re: Knock on front
Post by Will406td »
Will it be the ball looking one just looking on eBay and apparantly
they are all the same?
