Changing Windscreen Wipers?
- Bailes1992
Is it just my car or do all 406's not have fully liftable wiper arms? I cannot change my passengers side wiper blade as it dosent come off the screen enough?
Re: Changing Windscreen Wipers?
They're all the same, it's bluddy annoying
You have to rotate the little clip 90 degrees, then slide it along the arm.
- Bailes1992
I cannot get my passengers side to clip in tidy and it keeps slipping off and hotting my bonnet. I'l get the garage to sort it tommorow considering it's going in
You have to pull it in such a way that the wiper 'clicks' into place. You sometimes have to pull pretty hard. If you're confident that the clip in on right then just pull!!!!!! Please sign my disclaimer in the event you break your wiper arm
- Bailes1992
Thats what I'm scared ofeoin27 wrote:You have to pull it in such a way that the wiper 'clicks' into place. You sometimes have to pull pretty hard. If you're confident that the clip in on right then just pull!!!!!! Please sign my disclaimer in the event you break your wiper arm
Just give it to the garage as it has to go in for a whole host of things tommorow. Thing is it passed its MOT two weeks ago yet I just found the front ball joint N/S is knackered, the Bushes on the front O/S are knackered on the wishbones. Aswell I need to get the engine mounts fitted etc etc etc
Ah well
No real reason, just fancied doing it.
- Bailes1992
My clips dont look like thatsteve_earwig wrote:No real reason, just fancied doing it.
I know the sort, just goes inside the loop and has clips on the end that stop it sliding back up the arm. The trouble is they really need the wiper to be at 90 degrees to the arm (remove windscreen?
- Bailes1992
Might go to peugeot and see if I can get a valeo passengers side one with a decent clip. The drivers side wiper is pretty good (I got bosch wipers).
I bought the Peugeot wipers last week. Put them on backwards. The clip was too high on the arm but they worked ok. I put them on right but I broke the clip in the process. Does anyone know if I can just buy the clip off the stealer?
Why not try your local car spares shop? I tend to throw spare and old wiper clips in a box for those unexpected breakages, my local shop does that as well.
- 1.8 8v
I have to do this, might just pay Halfords 3 quid and get them to do it lol...............
