kevtherev wrote:gRoberts wrote:Just as a test, turn your Aircon on and see if the fans kick in, if they do, it could be your thermostat or wiring that's guff.
turned the aircon on . the fans DID NOT kick in... is this good or bad?? lol
They won't kick in immediately, only when the aircon radiator gets hot enough
kevtherev wrote:ive had a little look see and there are two fans next to each other spanning the entire width of the rad
they both kick in at about 95 degrees. its a 1999 t plate d8 1,8 petrol model. sorry for any confusion on which model the car is
Hmm I thought the 1.8 only had the one fan...
In any case, 95c is about where it should kick in at low speed (barely audible from inside the car), and that should be able to hold the temperature steady around 90-95c on any 406 engine. When it hits around 100-105c the fans should kick into full speed mode, which you WILL hear and feel. It's enough to dim the lights!
I suggest keeping an eye on the gauge next time, see how close to 100 it gets.
