nuts and bolts
marco2002
nuts and bolts
Post by marco2002 »
Just went into peugeot dealer today to order nuts and bolts for rear shocks (bottom part) and also some new nuts and bolts for the rear anti roll bar bushes. Guess what? They only supply them in bags of 5 or 10? So you end up paying over the odds for a couple of nuts and bolts! Anyone else come across this before? I'll just have to re-use the nuts and bolts on the bottom of the rear shocks clean them up and use a bit of nutlock on the threads. I was hoping to get a new set of nuts and bolts for the roll bar bushes sounds like they have a tendency to shear off if you're a bit unlucky.....
50 mile round trip to that stealer this morning what a waste of time!
djheath
Re: nuts and bolts
Post by djheath »
Reminds me of hot dogs come in tins of 10, hot dog buns come in bags of 6.
Sorry, I'm not helping am I?!
Re: nuts and bolts
Been watching the Bulletproof Monk again? :P
You should be able to get that sort of thing from an ironmongers, the questions are they up to the task?
omega
Re: nuts and bolts
Post by omega »
quite a lot of pug parts are like that
buy them and flog them on here
job done
marco2002
Re: nuts and bolts
Post by marco2002 »
Just have to hope none of the nuts or bolts shear off. lol
Been looking around on the net for some reasonably priced rear shocks think i've found them £32 each inc vat and free delivery. cheapest i've found even ebay is dearer.
marco2002
Re: nuts and bolts
Post by marco2002 »
just a quick update. went to nut & bolt shop today they matched up a new set of bolts for the grand sum of £1.50. look exactly the same as the originals
and high tensile as well. just goes to show what a rip off dealers are.....
plod
Re: nuts and bolts
Post by plod »
omega wrote:quite a lot of pug parts are like that
I had a wheel arch liner missing off mine, and bought new one from stealer.
Only it had an access panel missing - thing is about 5 to 6" long and 2 to 3" wide
Was told could only buy them in pack of 5!!!
Note to oneself - must keep eye out for one :cheesy:
1999 D8.5 HDi GLX - Sold :(
barryj75
Re: nuts and bolts
Post by barryj75 »
just done rear track arms and bought new inner nuts and bolts from dealer bolts £3.60 each and nuts £1.90 each i thought they would of came as a set.
marco2002
Re: nuts and bolts
Post by marco2002 »
I'm thinking about having a go at those soon. did you have much trouble getting the old ones off? At least you managed to get 2 nuts and bolts main dealer here said they come in packs of 10......famous last words
barryj75
Re: nuts and bolts
Post by barryj75 »
had to cut nuts off with dremal couldnt get grinder in tried bolt spliter and that snapped you must remember to makl inner bolts before you start as the have ovel fixed washer to set rear wheel alignment. didnt half tighten back end up when done
marco2002
Re: nuts and bolts
Post by marco2002 »
Back end on my 406 shimmys about a little bit. Got the roll bar bushes sitting here and will be getting droplinks and those arms as well. Hasn't been done for about 4 years so i think that could sort out the problem. Just hope the bolts come out easy probably have soak the whole lot in wd40 the night before having a go.
barryj75
Re: nuts and bolts
Post by barryj75 »
drop links came off ok, i put full tin of wd40 on track arms over 3 days and they wouldnt move im looking to change anti rollbar bushes as mot just around the corner
