sirwiggum wrote:MAF arrived, fitted, the car feels a lot better below 2000rpm.
However, the fuel filter arrived and it turns out mine mustn't be a Bosch, as it is the wrong shape. Will have to send the Bosch one back.
The one I need is similar to the Siemens filter, but I need the 2 pipe instead of the 3 pipe.
Tried a bolt with PTFE to block it, but it just started eating through the side of the plastic.
Fun and games
OK the 190162 fuel filter housing is impossible to obtain easily. I ordered one from the pug dealer but as I needed the car to move flat I also got one from a scrapyard.
It is not running perfectly, the hesitation seems to be there. I will grant though, that the 2nd hand filter housing is an unknown quantity. The dealer "new" housing arrived and hopefully, when I get a chance, will swap it round.
Otherwise, the TPS never arrived though I was refunded. If the new filter doesn't help this will be the next swapover.
When I get a further spare moment, I intend to open the 3 pipe and the 2nd hand housing and swap the filter elements, therefore having a "new" fuel filter housing, seeing as these things are like hens teeth.
What is the best way of opening the Siemens-style filter housings? I'm thinking of trying an oil filter strap.
