In all fairness I didn't do it on purpose. But I was bloody lucky I just popped it into the roundabout a little fast and let go of the throttle and it slid out... dunno how I caught itsteve_earwig wrote:Blimey, they must have been feeling in a forgiving mood
Project All Smoke, No Poke :)
- Bailes1992
Re: Project All Smoke, No Poke :)
- DaiRees
Yeah very prone to lift off oversteer is the 406, especially in the wet
- Bailes1992
Sorted out the tube and the wiring
I got illumination now
Oh and swiss, this is where you should get your feed...
- swiss
Cool, thanks. Now wanna lend me some squids pls so I can have a crack ^_^
The man with no car
That pressure line is the turbo fuelling advance thingy isn't it?
An air-cooled gauge eh? I like what you've done it's kinda cool, and I bet it's interesting to see the various pressures going on.
- Bailes1992
It really is interesting because even without full throttle at 3000rpm I can make 15psi. But also at full throttle at 2500rpm I can make 15psi. Peak boost seems to be 16psi at 3000rpm in 4th. It’s also interesting how you can make decent progress but only have 6-10psi or even less. Not only that I do a quite abit of engine braking and as the revs go up even with no throttle so does the boost.
- Bailes1992
Oh and that pipe sends the pressure to the fuel pump which them enables a little man in the engine with a bucket to pour fuel into the cylinders
- swiss
I believe 'boost compensator' is the term we're looking for here
The man with no car
- Bailes1992
You named your guy with a bucket Boost Compensator? Poor guy Mines called Allanswiss wrote:I believe 'boost compensator' is the term we're looking for here
So when you press the pedal this guy, Alan, gets a prod to work a bit faster with the old bucket of Diesel
I suppose as he gets older he gets 'less responsive' to throttle inputs
- Bailes1992
Right on the pillars of the doors is black vynil. The pillar on the drivers side door had vynil on it that was cracked quite badly do I decided to be shot with the lot
Heres a Before...
Pulled it off
Tidies it up with some tardis...
Give the car a clean including wheels and tyres..
And bobs your Uncle
Heres a Before...
Pulled it off
And bobs your Uncle
Awesome
That lower grill is begging for some Bluey bling!
- Bailes1992
Bluey Bling???
- DaiRees
Chrome strippageBailes1992 wrote:Bluey Bling???
- Bailes1992
No thank you I think chrome looks tacky
