Bailes
Same.teamster1975 wrote: I've ploughed more into my 406 than I bought it for but it's such a brilliant car I'd rather keep it than get something newer.
Hang on, your getting a downer because through your own choice you want to turn a £40-£50 job into a £525 job?Bailes1992 wrote:I love my 406 to bits, it's got so much charecter and it means even more cause it's my first car. I've replaced the engine mounts, refurbed the injectors, two new trail arms, new front driveshaft, new wishbones, just bought new breaks etc etc and even more etcI've spend £800 on a car I bought for £700
Now the back ends knocking and crashing about and is fairly unstable at fast right hand bends and general high speeds but is great at cornering left
I assume the rear shocks or something are knackered (well the N/S rear one at least) and if thats the case I want all four new shocks which come in at £175, then ontop of that I'l want to lower it because I don't want to put lowing springs on already used shocks so looking at another £350 at least. Is it time to send Bernard to the scrap yard in the sky or shall I just solider on?
Bailes
When I change anything to do with the suspension I like to change both sides. I don't belive in changing one component on one side. So two new rear shocks. I also know that one of the front shocks was changed about two years ago so I want to change the two front shocks while I'm at it!StevieboyTD wrote:Hang on, your getting a downer because through your own choice you want to turn a £40-£50 job into a £525 job?Bailes1992 wrote:I love my 406 to bits, it's got so much charecter and it means even more cause it's my first car. I've replaced the engine mounts, refurbed the injectors, two new trail arms, new front driveshaft, new wishbones, just bought new breaks etc etc and even more etcI've spend £800 on a car I bought for £700
Bailes
Doing both sides at the back makes sense, but what's wrong with the ones on the front? You're looking for faults that aren't there.Bailes1992 wrote:When I change anything to do with the suspension I like to change both sides. I don't belive in changing one component on one side. So two new rear shocks. I also know that one of the front shocks was changed about two years ago so I want to change the two front shocks while I'm at it!
So true, I was told when I got the coupe that there would be little to be done to it. Of course its me so heres the list of things to be done and things I did alreadyBlue406 wrote:Such is the lottery of used car ownership.
As in on the passenger side and drivers side????!!!steve-earwig wrote:Or then there was that time when a batch of Escorts came off the production line with disks on one side and drums on the other.
Seriously!steve_earwig wrote:Oh lord no. And perhaps it's been sitting around in an airfield for months. Or then there was that time when a batch of Escorts came off the production line with disks on one side and drums on the other.
My £500 406 V6 saloon was pretty bang on when I sold it for the coupe, having had only a few consumables (brakes, tyres) replaced. My £1000 V6 coupe has got through about £250 in parts and needs another £100 or so to get it just right. My £2500 Golf TDI has already had £300 off me and still needs the best part of £1000 spending on iteoin27 wrote:So true, I was told when I got the coupe that there would be little to be done to it. Of course its me so heres the list of things to be done and things I did alreadyBlue406 wrote:Such is the lottery of used car ownership.
