Which 406 ?
- highlander
- PowerFlow Shill
Re: Which 406 ?
Yes, you definitely can. And if you're not careful, the entire top of your head will fall off because your grin will be so wide it meets in the middle at the back of your head
Re: Which 406 ?
Ithink drop links are Typical for failing on any car, not matter how old the car is,Gary406 wrote:nothin at all wrong with it mate apart from a few clunks. usuall links .. says on advisory from april all links / tie bar/rod all have playlozz wrote:so how come your not pimpin the 406 gaz?
come on spill the beans whats up with it?
or are you like me just got bored of french cars
i've just had enough of malling with old cars and spending money on them that doesnt need spending.
as long as it gets me and my family from a to b i dont car anymore(must be my age hitting 28 now)
Re: Which 406 ?
004 Offside rear tie bar/rod has slight play in a ball joint
005 Nearside rear tie bar/rod has slight play in a pin/bush
ball joint and pin bush ? are these the toplinks then ?
- OdinEidolon
Re: Which 406 ?
Well, i do 70% motorway, it's not fun there. When I drive in my mountains it's another story.Doggy wrote:Oh yes, you can.OdinEidolon wrote:The 406 is just so relaxing I can't drive it as the chassis would deserve.
Re: Which 406 ?
im guessing this can only be toplinks or droplinks for rear ?Gary406 wrote:004 Offside rear tie bar/rod has slight play in a ball joint
Re: Which 406 ?
The second sounds like the horizontal link, whereas the first one could be eitherGary406 wrote:im guessing this can only be toplinks or droplinks for rear ?Gary406 wrote:004 Offside rear tie bar/rod has slight play in a ball joint
1999 D8.5 HDi GLX - Sold
Bring back my 406
Re: Which 406 ?
All ican say if its top links, They must be Well and truely shagged or the mot tester wouidnt of picked up on them,
or either that hes used his brains and tested them with the Weight of the car on the ground
ibet theres 1000s of 406s on the road with SHagged toplinks
Re: Which 406 ?
ye lozz it sounds like something is truely fked lol
its clunking bad from back end ... think i will change both toplink and droplink on the rear . only cost £20 for all 4
the front isnt to bad really but gonna get droplinks then all the links are done on all 4 corners ....
Re: Which 406 ?
ive just put new droplinks on the citreon again
1st set one failed after amonth, cheap ebay shite
just got some Qh ones, £8 each hopefully they wont fall to bits
got to replace both track rod ends too, everything seems to go one after the other on this car
Re: Which 406 ?
im only putting ebay ones on.. for £30 i can replace the whole lot both sets on rear and droplinks on front... bargain..
never had any problems with ebay ones yet me... probebly cos i avoid pot holes. im forever swerving round them
Re: Which 406 ?
Weve got speed humps all over up here so, they dont last on anycar we have,
the last ebay set igot where for the 406 ended up giving the buyer afew sets as iknew they where failing again,
he still rang back after 3 weeks moaning saying they where expensive to have fitted
Re: Which 406 ?
Both rear wheels on the 406 have a lot of play...
will ask jasper to check it out for me on saturday...
