The Focusaurus :) ... May Contains traces of Ford!
Re: Project Besty... WARING Contains Ford!
I'd think it would be cheaper to pick up one from the breaker's than get the wheel repaired. Probably safer too (do the repairers there have x-ray machines to check for cracks?)
- Bailes1992
I'm going to a quite well known place down on the industrial estate. They have a good rep around here. If not a new alloy is £125steve_earwig wrote:I'd think it would be cheaper to pick up one from the breaker's than get the wheel repaired. Probably safer too (do the repairers there have x-ray machines to check for cracks?)
Who said anything about new?
I get the point though, how do you know what happened to one from the breaker's (unless you pull it off the car yourself). If you do get it repaired make sure it always lives on the back of your car.
- Bailes1992
I'm sure it will be fine once it's repaired. If it wasen't safe I'm sure they wouldn't be able to do it in the first place!steve_earwig wrote:Who said anything about new?I get the point though, how do you know what happened to one from the breaker's (unless you pull it off the car yourself). If you do get it repaired make sure it always lives on the back of your car.
Scrappys want silly prices for alloys too and will only let you buy them in 4s! I might just say f*ck it and buy new, but it's 2 weeks wages
Surley having a wheel go on the fron't of the car is safer than the back? Afterall if one went at the front, chances are you won't spin out. On the back you may do!
My missus car looks like that on the inside, they really don't give a sh*t about their cars do they
I'm sure you'll keep it clean now though, and to be fair that's a decent car for a young whipper snapper like you
- Bailes1992
Just got a price to have the wheel sorted for £25. Happy with that
That's ok, it costs that here. I'd still worry about sticking it on the front but I've had a search and can't find anything on a straightened wheel failing.
Hold on a mo, why's this in the "Pug pictures" forum
- Bailes1992
I noticed a few weeks ago one of the wheel bolts looked like it had been replaced by a normal bolt? Then after a bit of investigation I found out the ford put an aluminium cap over the standard bolts to make them look better. Few pictures to explain...
And as you can imagine, the wheel looks much nicer with a matching set of bolts now
Although Ford wanted £7.99 for the bolt
They're NUTS!
I've had them on other cars but made of plastic (the Scirocco had them, I made a tool for removing them), are you meant to take them off before undoing the nut?
- Bailes1992
Nope! I physically cann't remove the cover on the nut, and without them the standard wheel brade just slipps off and rounds the nut down. The wheel nuts are 19mm, I used a hammer and an 18mm socket to get it offsteve_earwig wrote:They're NUTS!![]()
The old ones were probably taken off with the wrong size socket on an impact wrench (sweep it under the car quick...)
- DiscoPol
- Shiny New C5 2.2 Bi-turbo!
My Landies nuts are also covered
though mine are 27mm, not to boast like
but your only young so small nuts are to be expected
- Bailes1992
It's ok... its not the nuts that matter ;)DiscoPol wrote:My Landies nuts are also covered![]()
though mine are 27mm, not to boast like![]()
but your only young so small nuts are to be expected![]()
But as you know... as bearings get old and used they stop working as well as they once did ;)
- DiscoPol
I want to come back with some smart arsed remark, but sadly young man, you are rightBailes1992 wrote:But as you know... as bearings get old and used they stop working as well as they once did ;)
enjoy it whilst you can
- Bailes1992
Are driveshafts supposed to have any movement in them? Trying to investigate a front end knock, jacked the car up, couldn't find any knoocking or looseness in the wishbones but then again, I'm a puff and not sure how hard you need to shake them, grabbed the drop links and theres no movement in them either. But when I grabbed both driveshafts theres about 1-2ml in and out movement in both of them? Is this normal?
