Estate rear screen heater problem
Re: Estate rear screen heater problem
So you have power across the terminals, continuity across the heater element and yet it still doesn't work :?
I can't see how a small amount of corrosion would stop it working.
HR somewhere? Try a bulb across the terminals.
Kiwi
Post by Kiwi »
steve_earwig wrote:So you have power across the terminals, continuity across the heater element and yet it still doesn't work :?
It works, but it is very slow now to get warm to the touch. Before, with the car outside in -14C it would melt the ice in a couple of minutes, ( by the time I'd scraped the side windows ) and I could feel the heat. Even just to demist it takes ages now compared with when I first got the vehicle.
I've seen them steam but I've never felt one get warm - I'll soon get an opportunity to try it I guess.
Ok, how about checking the voltage across it with the heater running? If it drops significantly you're looking for a bad connection. If not then we have to assume the window heater element is in trouble :(
Kiwi
Post by Kiwi »
steve_earwig wrote:I've seen them steam but I've never felt one get warm - I'll soon get an opportunity to try it I guess.
The voltage I measured was at the lucar terminals with the heater running. Do you mean to measure the voltage on the actual element / screen where the termimals
attach or.. where ? Yes, it used to steam before and if the screen was fogged it used to clear in minutes. when it was steaming was when I felt it was warm. Thanks.
So this 14.5 volts was measured across the heater element from the actual connectors themselves, with the element turned on & the engine running? I was thinking maybe a bad connection elsewhere was dropping the voltage enough to stop the window clearing effectively but that kind of rules out that idea :(
Arnt these wired in sequence with a Timed Relay?
noticed on the picasso the heated screen turns itself off after a min,
dosent seem to clear condensation very good, not had frost yet to try it properly,
The 406's, (well mine at least), stays on for 10 minutes.
Kiwi
Post by Kiwi »
I think the problem has been fixed. When I refitted the loom spade connectors to the screen terminals I noticed that they were tight to push on but were not " secure ",i.e., they rocked on the spade terminal. I used a thin blade screwdriver between the terminal and the insulator sleeve to tighten the female terminal and the result was a secure connection.
Yesterday morning I had a couple of mm of ice on the screen ( -5C ) and the ice was melting while I was scraping the front screen. Here's hoping..............
Thanks to all those who have offered info.
