as I said above I have a clone from god knows where and it never would speak to the engine ecu (siemens) so i decided to take a punt on an earlier version and it has worked a treat. I am not sure if its a full complete version or even a hacked up version but it sure does let me read and config the siemens engine ecu + the rest.
If i had somewhere to upload this version to i would. its 943 meg unpacked and 500 + meg packed up so is a bit large to find a home online for it.
BSI vs Engine ECU - Can't access Engine ECU on PP2000
Re: BSI vs Engine ECU - Can't access Engine ECU on PP2000
406 D9 2002 in Met blue . Full leather interior. Fully working puddle lights (LED's). Both interior lights work from the front switched light (LED's). Door handle Lights (internal LED's). Yup i love LED's but not as much as the BSI does .
- rwb
09.B (22.14) didn't work. 10.A (23.25) did.
What versions do you have?
Where are you guys gettings these old PP versions from? As I'm having trouble downloading them
Could someone who has some maybe PM me please?
Thanks in advance
Thanks in advance
- rwb
It's the version that comes on the CD that comes with the cables!
Since the newer versions just add support for newer cars -- and there's no danger of me getting a newer car any time soon -- there isn't any need to upgrade!
What exactly are you after?
Ah ok, fair enough.
Well the disk that came with mine had Diagbox 6.01 and an update for PP2000 v24.something. Am I right in thinking that Diagbox is the newer software that superseded the older (v22, v23 etc.) standalone PP2000?
I'm having trouble reading the engine ecu in a Siemens HDI 406 estate and am using the Diagbox 6.01 that came on the disk, as I always have on all other cars I've used the interface cable on.
So I guess I'm looking for PP2000 v22.14 and failing that, v23.25 that you mentioned worked for you
Would anyone be able to help me with the aforementioned software? Thanks
------- edit -------
I've managed to find PP2000 V22.14 and the v23.25 update now, so if anyone would like it let me know
