Vibration at idle and grumbly on acceleration
grasmere59
Re: Vibration at idle and grumbly on acceleration
Post by grasmere59 »
VespaSkin wrote:Problem is I think I have DMF lower pulley on a non clutch alternator (lower mount has rubber windows in and alternator has a large nit in middle of it and not the splined one though I do have a spare alternator that is clutch)
My car has the rubber type bottom pulley but according to service box it should have the later solid type one,i'm confused as to what it should have now it's got a solid flywheel,as for the clutch type alternator i haven't got a clue what its got fitted. :?
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
VespaSkin
Post by VespaSkin »
Right - keeping pug - still getting 750 - 800 miles per tank (73lt) - current plan...
Plan A - cheap option - new solid flywheel, 1x gearbox and 1x top engine mount, rebleed clutch and fit (now confirmed) lost intermittent bearing holding bolt
Plan B - the above but with a new complete driveshaft
VespaSkin
Post by VespaSkin »
Do we reckon this would be OK for a V reg 2ltr hdi 110 estate (lx)?
4477/515s4..........BRAND NEW SOLID STEEL REPLACEMENT CRANKSHAFT PULLEY TO FIT VARIOUS CITROEN/PEUGEOT 2.0 HDI MODELS...REPLACEING TROUBLESOME RUBBER DAMPED ORIGINAL TDV VERSIONS ON......PEUGEOT 206,306,406,607,806,807,PARTNER,EXPERT,BOXER...........CITROEN BERLINGO,DISPATCH,PICASSO,RELAY,XANTIA,XSARA,SYNERGIE,C5..........ONLY FITS 2000CC HDI DIESEL ENGINES FROM YEAR 2000-06...engine codes DW10TD..DW10TED......SEE SEPARATE SHOP LISTING FOR 1.9 MODELS ...........12 MONTHS GUARANTEE..for telephone payments please call our shop on 0161 6286199..mon-sat
http://www.ebay.co.uk/itm/PEUGEOT-2-0-H ... 45f83a5ee9
grasmere59
I thought the solid ones were for the later cars only,might be wrong though. :?
VespaSkin
Post by VespaSkin »
Cheers
VespaSkin
Post by VespaSkin »
Hmmmm, how much movement should there be on the gearbox engine mount, you can certainly see it move... not subtle like rear or timing belt side which is more of a vibration movement that a big shift... problem 1 solved???
VespaSkin
Post by VespaSkin »
Cheers everyone but I've given up on this and have got another motor, I'll either weigh in or part break this one.... picked the other motor up earlier...
ANOTHER 406 110HDI - 2003 - £550 WITH 9 MOONS MOT AND 7 MOONS TAX
