406 HDi 90 Died on me
I bet one of the pressure springs on the clutch plate has snapped off, jammed the clutch a bit and took out the cps at the same time. In other words the clutch has fallen to bits.
You will therefore be into a new clutch (not too bad on yours, cost wise) and the cps.
I suppose if the cps is not reading then the ecu will not think that the engine is turning over right?
jameslxdt
Post by jameslxdt »
if that ever happened welton, it would get stuck between the friction plate and pressure plate and the clutch pedal would be stuck halfway to the floor
i have spoken to my dad (pug master tech) and he does say that the HDi 90 did have a dual mass flywheel and this sounds like the typical symptoms
rossd
Post by rossd »
Sorry dude, but the HDi 90's didnt have a dual mass flywheel as others on here have said, I've done enough clutch jobs on them to know!
110's from 1999 and the 2.2's had DMF's, not the 90.
2003 406 S HDi 110 Estate
