Sorry not 406 related,
jonsowman
Re: Sorry not 406 related,
Post by jonsowman »
grasmere59 wrote:On my 406 the fan always runs at a low speed i think even when switched to the off position.
Same on mine :)
So if thats normal for the fans to stay on,
imight have a go at Getting the Air con working, all the pipe work looks healthy enough, apart from the stray hose thats s'posed to fit on
the blower motor
anyone used the Halfords top up cans?
last time itried it on another car icouidnt get the system to draw it in,
thinking of bridging pins 1 and 3 on the preasure switch, and see what happens,
http://www.peugeotlogic.com/workshop/ws ... fanop1.htm
grasmere59
Post by grasmere59 »
turn the radio up :cheesy:
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
Lozz if it's low on gas then it's leaking somewhere for sure. You'd be wasting your time and money trying to add gas (and it's not exactly good practice :supafrisk: ). It's most likely the condenser is corroded at the bottom.
Yeah true,
iwill take it to Kwikfick and get them to Gass it up,
lozz wrote:Yeah true,
iwill take it to Kwikfick and get them to let the gas piss out all over the place,
More like it :roll:
Sorry mate, bit of a pet hate of mine and something I've had a lot of dealings with too. I've read many times where people have been to garages, had the a/c fixed, and then it breaks again 2 days later - it's all because it wasn't tested properly.
The correct method is:
  • Safely recover any old gas.
    Carry out Nitrogen pressure test - something like 250PSi on the gauge and monitor for at least 30 mins watching for pressure drops.
    If successful, vacuum the system to remove moisture (another 30 mins at least).
    Fill system with correct weight of refrigerant (vital) and correct quantity of oil for lubrication (also vital).
    Test air temps (looking for 5 to 8 deg C at the vents).
A new receiver/drier is recommended especially if the system has been 'empty' for some time.
cheers.
Theres no gas in it totaly bone Dry,
ionly use kwickfick because, if it dont work you dont pay nowt,
everywhere else charges even if it dont work and they take back what theyve put in,
