HDI running problems
mark21TD
2.2 16v
Re: HDI running problems
Post by mark21TD »
Not see this yellow plug, but this is a 306 not a 406 so do you know if it still has one.
In-tank pump was lined up as it was before removal.
The fuel filter was changed in the early stages of this saga.
406 2.1TD GLX estate
Xantia 1.9TD VSX estate
brew my own biodiesel
madmadmax
Post by madmadmax »
both the 306 and 406 have the loom extension you will need to look from the under side in the middle of the car roughly and it may be black with grime
madmadmax
Post by madmadmax »
