406 1.9 HDI Won't start after Breakdown
jameslxdt
Re: 406 1.9 HDI Won't start after Breakdown
Post by jameslxdt »
check the cam timing and make sure the timing belt hasnt slipped or snapped, if that checks out ok, the scope the crank sensor, if you get a good signal then scope the cam angle sensor, if this produces no signal then change the sensor
