jameslxdt wrote:has the car ever been jump started?
also check to make sure that the correct amp fuse is in place for the ecu
has been jump started a few times. but not for a while. worked for ages after last jump start.
Fuses all ok. I am guessing it has the right fuse. had car from new and i have never changed any of them.
The D9's are infamous for weak electrics and apparently jump starting is a big no-no. James has mentioned this in a past thread but it was quite a while ago.
steve_earwig wrote:Jump starting: most cars are packed with ECUs and many of the don't take kindly to the sort of swift voltage changes you get with jump leads. Disconnecting them can be just as dodgy, if you must leave them connected for a full 3 minutes. The recommendation seems to be throw your jump leads away & never have anything to do with them again.
