alarm, key in boot, auto windows?????????????
damo406
Re: alarm, key in boot, auto windows?????????????
Post by damo406 »
be carefull cos the rubber bit on the end of the lock was a bit of a mare to cut off with out cutting into the wires.
my missus hasnt got a lock in the boot but her siren still dont go off dose any1 know where it could be in the coupe?
ordered a dvd repair manual off the net the other day so hoping it says something about it on there where it arrives.
i got a total closure kit and the instructions are in jibberish :shock:
damo406
Post by damo406 »
woo hoo
auto windows are finished after a week of trying to work out the wiring on the total closure kit realised that i didnt need it after all :shock:
all i needed was a different plug to connect to the window motor (the plug off any 406 with rear electric windows) so any1 that has rear electric windows this is a matter of only connecting 1 wire and job done when you lock the car the windows will close too hope this helps any1 else wanting auto windows :D
Well done Damo! I haven't done anything with that lock in the boot yet, I might try jumpering it to see if it does anything.
damo406 wrote:any1 that has rear electric windows this is a matter of only connecting 1 wire and job done when you lock the car the windows will close too hope this helps any1 else wanting auto windows :D
Can you elaborate a bit please? Which wire (from where to where)?
damo406
Post by damo406 »
i had a look through the haynes manual about the alarm and it dont say jack about the lock in the boot or where the siren is locater its pants and it doesnt cover the sri really well worth 18 quid :evil:
and while looking through the wiring diagrams i found loads of mistakes they have made to confuse every1 :x
I've spotted a few errors in the wiring diagrams too, where there's something missing or where the wiring is just plain wrong. I think that's in what they mean by the word "typical" - "we don't really know but cars in general are typically like this so it'll probably do."
damo406
Post by damo406 »
ok if you take your door card off and un plug the motor to your window and look in the plug the connectors are numbered 1-9 the cable coming out of conector 6 (the cabes have the numbers 6261, 6262, 6263, 6264, on them ) needs to be conected to the live switch wire from your door lock not sure if you have to do it to each door though
hope this helps if you need pictures or any more info let me know
nutski
Post by nutski »
I'd be interested if you could put up some pics to do the auto closure please? :cheesy:
1997 2.1 TD Exec (Sold)
1997 3.0 V6 Coupe S (Sold)
2001 406 HDi 110 GTX (Sold)
2002 406 Coupe HDi SE (RIP)
2001 406 Coupe 3.0 V6 SE
2003 406 2.2 HDi SE
damo406
Post by damo406 »
heres a picture of the end of the plug
i have done the numbers so they're a bit clearer
connector number 6 is the one you want not sure what colour it is but the rear drivers side (the one i got from scrap yard) is purple but this may not be the case for all of them but the cables are numbered on the cable:
front drivers door- 6261
front passengers door- 6262
rear drivers door- 6263
rear passenger door- 6263
you may be able to just jump off one of these cables (cut and rejoin the cable and add another cable like a y ) to go to the lock and it may power the rest but not sure as i only have the front electric windows.
you will need to find the switch wire that comes live when you lock the door with a multi meter (cant remember what number this cable is but ill have a look when i get a chance)
sorry if its a bit vague. ill take my door card off and take some more pics
I'd be extremely wary about doing it that way. It sounds like you're keeping the window motors live while the car's locked, which could burn out the motors and/or flatten the battery. The thing with the factory total closure system is it only powers the windows as long as is needed to close them
damo406
Post by damo406 »
the power is regulated by the motor though. so when the motor recognises the window is closed it cuts the power so its not using any power.
thats why when you disconnect the power to the window you have to reprogram it aint it.
i have had mine done for 2 weeks now and works ever time and had no problems at all
Deano
Post by Deano »
teamster1975 wrote:
damo406 wrote:thats what i thought but i cant find any thing i thought that the lock in the boot might have been it but no such luck
i wouldnt even know where to start looking
I've just had a look in my car and I've got the same lock inside the boot (and no key to fit it :frown: ); it must be for disabling the siren.
I'll have to try splicing the wires & see if it works![/quote
Hi 1.the lock in the boot is an over ride switch to turn the alarm off
2. the standard siren is behind the bumper in a tin box under the boot floor o/s/r wheel arch if you jet wash under the wheel
arch it can damage the siren
2.0L 8V TURBO EXECUTIVE 150BHP+TOYS ZRX1200R AND MK1 EUNOS ROADSTER
damo406
Post by damo406 »
excellent nice one
did you manage to find out how to get it working at all?
dragonslayer
Post by dragonslayer »
im trying to do auto windows too has any ones else done this
dave
StevieboyTD
Post by StevieboyTD »
damo406 wrote:...
Idiot question, what does this button actually do?
2.1td exec estate.
