Clutch Pedal sticking down
Re: Clutch Pedal sticking down
The spring doesn't do much at all apart from altering the feel of the pedal - the returning action is by hydraulic means
Daveyravey
Post by Daveyravey »
The pedal return spring is only there to bring the pedal back to the same height every time it's released.
I'd def start with the slave cylinder & take it from there & i can't see it being the master cylinder seal as you would be loosing fluid
captainsparkledotcom
Post by captainsparkledotcom »
How strange,
Mine does the same thing, it's as if it's suddenly worn and you have to push the pedal back up with your toe!!
It started a few months ago, when you 'adjust' it back up it's grand, like new,
which it is now, just had a new clutch after it wore out (it's a taxi, you know)
Any more thoughts/solutions since this was last posted?
cheers.
PYROMANIACS OF THE WORLD IGNITE!
http://WWW.captainsparkle.com
