New battery time?
- Captain Jack
Re: New battery time?
Also available from here.
- This one doesn't look like it needs welding?
I'm fairly sure my flexi section is leaking too, but they don't list mine
If you do get one CJ, I'd really appreciate some measurements - might save me shelling out for a cat as well
- Captain Jack
Yeah, very confusing! If it's one piece, how are you supposed to separate it?
Hi gents.
It would be best to find out which front pipe/cat is fitted to your particular car so you can tell if there is a possibility to fit a joining piece after the flexi bit onto the cat.
If you look on here....http://www.leisureshack.co.uk/peugeot-4 ... ystem.aspx, you can see there are a couple of different types of front pipe/cat fitted.
If either of you would like me to check out what is available to repair your front pipes, please PM your reg number and I will check with my local suppliers what is available.
These places that do 'Powerfow' stainless eggsauces might be a good bet I reckon. Wouldn't hurt to ring one up and explain the job or pop down even?
They'd have to drop the down pipe, get it on a bench, cut ...etc etc and probably a new clamp/seal at the turbo end?
I was quoted £60.00 I think for that old BMW Diesel we had.............It never did get done
Edit, Jasper beat me to it - good suggestion Jaspy.
- Captain Jack
Something tells me mine will be this one (DW10ATED) where it doesn't look like the flexi hose is replaceable without the cat. Oh well...
Sorry Welly
Yes CJ, that looks like yours according to my info, but it can be fixed.
£120.00 aint too bad really, especially if you end up spending £70.00 odd quid on a patch up which may not work?
Can't remember exactly how much mine was (in amongst the £1,200.00 bill) but £140.00? rings a bell.
Cap'n - you might get some cash back on yer old CAT if you sell it to a gypsy for 'recycling' - it'd save him hacking one off in a car park
- Captain Jack
Where do I find such a gypsy?
Most parts of the Midlands.
jasper you have PMjasper5 wrote:If either of you would like me to check out what is available to repair your front pipes, please PM your reg number and I will check with my local suppliers what is available.
Thanks,
