I was breaking a car, but not anymore
Re: I was breaking a car, but not anymore
cheers mate
mine hasnt got that lift up part ,, looks good and handy that tho,
on mine its just flat but theres plenty of room underneath it where iwill be bolting my amps in,
the Lx speaker covers look a bit plain so iwill grab some jbl ones from the breakers yard,
thanks for showing us the pic
The first aid box is handy for the first aid stuff and now the pp2000 stuff
OdinEidolon
Post by OdinEidolon »
lozz wrote:What is this clip thing made of?
if its got any metal parts in it thats Glueable try some JB weld that stuff will Mend anything :wink:
Nah, it's made of some absolutely unweldable plastic. Tried with plastic specific loctite but with no effect.
OdinEidolon
must be that abs plastic like garden furniture is made of, and theres on point using a soldering iron i think its thermosetting so it wont melt.
OdinEidolon
FarmerPug wrote:must be that abs plastic like garden furniture is made of, and theres on point using a soldering iron i think its thermosetting so it wont melt.
Yep, but I think soldering iron won't grip enough: it's made to solder iron, which has a very different molecular structure to ABS. I'll do some more research.
Its made for solder but it can melt and join thermosoftening plastics I've done that before but it won't work for abs
Hareldite is good on plastic,
dont know if thats spelt correctly,
soldering iron is not much good for welding plastic,
Blow torch and a old thin pointed screwdriver works tho ive used the Gas cooker for heating screwdrivers up in the past
not good welding plastic in the kitchen tho :oops:
araldite
its good stuff yes, always worth a try when superglue fails
The soldering iron method, it can melt the plastic but ideally if your welding plastic together you need to feed in new plastic to help bond the two bits.
ive heard that stuff dentists use for fillings is good,
irember my mate saying he bought some from the chemist when his false tooth fell out he glued it back in with the stuff
dont know what its called tho but hes glued stuff on his Model steam boat with what he had left of it,
so its good on plastics ipresume,
OdinEidolon
FarmerPug wrote:araldite
Bicomponent glues are good for plastics usually, but once open do not last long (listening to my near-home seller), and I don't want to spend 6€ for a single, 2mm², use.
can you take a picture of the broken bit, then we will try and tink of some ways for getting it back together.
OdinEidolon
FarmerPug wrote:can you take a picture of the broken bit, then we will try and tink of some ways for getting it back together.
that looks easy to fix,
Fine dril bit dril through it and screw the thing toghether,
bit of black silicone wouid hide the screw head afterwards :roll:
OdinEidolon
lozz wrote:that looks easy to fix,
I've never seen a screw so small it could be used on that tiny piece of plastic. I thought of it too but it's just too small.
