Cruise control d9 1999 hdi110 **pls help!!!**
Re: Cruise control d9 1999 hdi110 **pls help!!!**
so is it possible to fit cruise control to any hdi after 2001? i'm very very interested!
Important update!!!![/color]
i quote from my earlier post:
""he then noticed cruise in the options list , it was marked as 'absent' so he clicked this, a dropdown list appeared an he selected 'present' also in the engine ecu list he found something called (from memory ) "survient-vitesse" also marked as absent so we guessed vitesse ment speed in french so marked this as present.""
SURVIENT-VITESSE
DO NOT ENABLE THIS FUNCTION !!! AS I DID UNLESS YOU WANT THE DASH BUZZER GOING OFF AT 76+ MPH!!!
ITS A SPEEDING WARNING AND SO ANNOYING.
I HAVE JUST HAD MINE SET BACK TO 'ABSENT' AND ALL IS PEACEFULL AGAIN
SURVIENT-VITESSE
"A HDI Is For Life and NOT Just For Xmas!!!"
HiBigGav75 wrote:so is it possible to fit cruise control to any hdi after 2001? i'm very very interested!
I dont know about post 2001 -sorry,,
I fitted cruise to my '04 Partner 90BHP HDi, if that's any help
2000 406 Coupe 2.0
2004 Berlingo 2.0HDi
"Survient à ce vitesse" = Happens at speed (if my French is still any good)wasp wrote:SURVIENT-VITESSE
DO NOT ENABLE THIS FUNCTION !!! AS I DID UNLESS YOU WANT THE DASH BUZZER GOING OFF AT 76+ MPH!!!![]()
I HAVE JUST HAD MINE SET BACK TO 'ABSENT' AND ALL IS PEACEFULL AGAIN![]()
How did u do this? what parts are needed?coco wrote:I fitted cruise to my '04 Partner 90BHP HDi, if that's any help
First check that you have the switches on the brake & clutch pedals. I was told I could only do it if I had the remotes for the radio on the steering column - I did. I don't know if it would work if you didn't have these already
On mine I bought the stalk from Pug, fitted it myself ( just a case of a small cut out in the steering column surround, remove a blanking plug, slot in the stalk and replace). then a trip to Pug to have it programmed into the ECU/BSI gubbins.
All in about eighty quid
2000 406 Coupe 2.0
How would i check the pedals? what would i be looking for? or would i need to take to stealers?
Get your head right under the drivers footwell and have a look/feel around the tops of the pedals, near the hinge. If you have the cruise control switches you'll have a switch behind the clutch and two behind the brake pedal. If you don't you'll only have the one on the brake
would the 2 on the brake pedal be right up beside/behind the steering coloum
Can't remember. I think they're mounted horizontally on a plate attached to the pedal, and there's a plate attached to the body right next to it, which pushes the switches. The plates are the same on cars without the cruise control switches, but there's a hole where one should be
Gav, if you've removed the trim panel that covers the fuses and bsi you'll be able to fit your head in the foot well and have a look up, follow the brake pedal up as far as it goes and if they are there you cant miss em , should be two sitting next to each other, I've got em on mine, i think there quite common
2000 2.0 HDI Estate GTX 90 bhp
