Cruise or not ? UPDATED NEWS, CRUISE FITTED! YEAAAHHH
leehdi
Re: Cruise or not ? UPDATED NEWS, good news, retrofit possib
Post by leehdi »
Cheers lads :)
Although that has put me one step back in fitting it to a 206 :lol:
RayneR
Post by RayneR »
well, mine looks like a big giant plug, and i can't find " variant " anywhere on the sticks
hahahaah now what came up to my mind ? THE sh*t LEXIA CLONES DOESN'T WORK ON MY 406 BECAUSE MY 406 is K LINE BASED DIAGNOSIS !!!!!!!!!!!!
btw leehdi , what's about being k line and not ? what's the difference ?
leehdi
Post by leehdi »
That's a variant one. The normal one is three plugs like on the other picture.
PSA-XS Evolution interface should read K-Line :? Mine does
It's nothing to do with this project really, its just the thing it uses for coding and diagnostics. K-line is pin 38 on the connector for future reference :wink:
RayneR
Post by RayneR »
leehdi wrote:That's a variant one. The normal one is three plugs like on the other picture.
Well i know it's nothing to do with the project, but why it's different then the normal ? there must be always a reason lol...
I tested 2 lexia clones and none of them were able to diagnose my engine ecu ...
leehdi
Post by leehdi »
The 3 plug is canbus network. The one plug is standard electrics.
Does it even recognise the ECU, or does it say not replying?
RayneR
Post by RayneR »
leehdi wrote:The 3 plug is canbus network. The one plug is standard electrics.
When it trys to communicate it says not replying ... one of the clones was able to recognise " a bit " of the engine ecu, it said " unknown peugeot reference " or something like that, and was also able to recognise the ABS and airbag ecus , and the other clone was neither of the two ....
leehdi
Post by leehdi »
What version software are you running?
RayneR
Post by RayneR »
leehdi wrote:What version software are you running?
tryed an old one the 22.12 and the lastest 24.something and even the new peugeot software the DiagBox ( well this actually is new only to new cars, the older ones still opens the pp2000 ) ...
So .. what it could be ? i could enter in BSI and stuff but engine ECU nop ...
Well i have a conclusion ...lexia clones aren't good ...
leehdi
Post by leehdi »
Where did you get the clone from?
I'm running v5.34 on diagbox and it works fine.
Wonder if you ran a wire straight from the interface to the ecu using K-line. Not sure if that would work :?
RayneR
Post by RayneR »
leehdi wrote:Where did you get the clone from?
One clone is from my mechanic, the other one was from another garage... so no way to know where they get them ...
pugi406
Post by pugi406 »
Can I have cruise on my db9 2000 1.8 ?
ZilogJones
Post by ZilogJones »
I take it this can't be done on a Com 2000 406? I looked behind the blanking panel for the switch on mine, the connector block is there but there are no wires behind it :cry:
2002 2.0 HDi 90 Rapier saloon (for sale)
On com2000 cars there is no switch on the dash, it's all in the stick. Have a look at the pedal bracket for the connector for the second (red) brake pedal switch. Mine doesn't even have the connector, all I have is the hole in the pedal bracket for the switch, I read that they don't always have it so I have to run a wire from the engine ecu all the way to the pedal bracket :frown:
RayneR
Re: Cruise or not ? CRUISE FITTED ! YEAHHHH
Post by RayneR »
YEAHHHHHHHHHHHHHHHHHHHHHHHHHHHH.
CUISE CONTROL WORKING !!!!
All i needed after all was changing my ecu, my original ecu didn't have the cruise/remote codification in it's features, my friend's 406 from same year had an ecu which had it and found one like he's.
Unlocked and coded, function programmed, tested = 100% working
:mrgreen: :mrgreen: :mrgreen: 8) 8) 8) 8)
Re: Cruise or not ? UPDATED NEWS, CRUISE FITTED! YEAAAHHH
Well done!
Must feel great to finally get it sorted out, pleased for you. 8)
Can you now 'talk to' the engine ecu with PP2000?
