My Beautiful ''Miss Pug'' [A Working Progress!]
Sonia406
Re: My Beautiful ''Miss Pug'' [A Working Progress!]
Post by Sonia406 »
jonsowman wrote:Bullet connectors are also fine, perhaps easier to get hold of but a tad more difficult to mate/unmate. As long as it's a solid, well insulated and strain relieved connection, go for whatever you can get your hands on!
Yep, the connectors will either be press fitted into the metal frame (just pull them out) or cable tied on (cut and replace).
Ahhh I see... I think the bullet type may be easier to fit? Thanks :D
I shall have to have another look in the light, I think they were just pressed into it but didn't want to be forceful as knowing my strength I do more harm than good, bull in china shop scenario! :lol:
Miss Pug 2001 - 2023.
Just don't pull every wire out & reconnect with the bullets. Do one wire at a time (cut it either side of the plug) & connect with the bullets until the flashing light goes out. If I'd known about your plight a few months earlier, I probably would have had a complete seat wiring set that you could have had to use for trial & error as I had a bare seat frame sat in the shed (along with lots of other bits). As it stands I still have a fair few small 406 bits in there, but the larger stuff ended up at the dump to make space for the Xmas stash.
My post from all the bits I had is probably still floating around in the for sale section. Didn't get many takers for anything though.
Sonia406
Post by Sonia406 »
waue1978 wrote:Just don't pull every wire out & reconnect with the bullets. Do one wire at a time (cut it either side of the plug) & connect with the bullets until the flashing light goes out. If I'd known about your plight a few months earlier, I probably would have had a complete seat wiring set that you could have had to use for trial & error as I had a bare seat frame sat in the shed (along with lots of other bits). As it stands I still have a fair few small 406 bits in there, but the larger stuff ended up at the dump to make space for the Xmas stash.
Ohhh that's a damn good idea that...... one at a time until the light goes out (hopefully, goes out)
You seem to have a lot of parts from your 406, how did she meet the end, did you just scrap her?
I will go and check your sale post - JUST in case something takes my fancy :lol:
It was still going when I sold it:
viewtopic.php?f=20&t=10942&hilit=+family
I was assured that we didn't need 7 seats anymore as the Irish contingent wouldn't be making too many trips over, & was also told that we didn't need an estate as we'd had the 406 for 2 years & the dogs never went in it.
So I got this (which was something I'd always wanted ever since they came out):
viewtopic.php?f=20&t=17565&hilit=+530d
Once the 406 was sold I learned that a 2 ton 3 litre diesel with an auto gearbox only does 18mpg around town (& can also turn the driver into a bit of a hooligan), so I did the math using this:
viewtopic.php?f=5&t=17592&hilit=+530d
& found that I would actually save money over 12mths by putting £1500 on top of the Beemer & getting a Partner/Berlingo.
Now that plan's been screwed by the renewed requirement for the occasional extra seats.
Sonia406
Post by Sonia406 »
Ok - So just got this reply :shock:
You cannot use Anderson power pole connectors for airbag connections.
Any connection on an airbag system must, when disconnected, automatically short out the two cables feeding the airbag. This is done primarily to prevent the air bag detonating when being disconnected and the secondary purpose is to show zero ohms resistance to the airbag ECU should a fault develop within the wiring of the airbag system.
You must utilise the correct original connections or you could create more problems than you already have.
Most vehicle manufacturers do sell plugs and sockets to fit their wiring looms. If you get no joy with Peugeot, I know for a fact that Mercedes sell all their plugs and sockets separately. You just need to find a Mercedes parts dealer who will be happy to spend some time locating some suitable plugs and sockets but they must be for the airbag system, other wise they will not have the shorting link across the two pins.
What are your thoughts people?
Sonia406
Post by Sonia406 »
Seen the album on Facebook - HOW many cars? :shock:
Most of the photobucket hosted images on here are broken linked though, and won't show in the topics :(
You certainly have had a LOT of cars............. and naughty naughty, not all Peugeots :lol: :)
Sonia406
Post by Sonia406 »
Decision made: Going to just solder them together and tape up using coloured tapes so I know what was what.
I honestly can't be bothered with this connection thing, IF the seat ever needs to be removed it will have to be cut!
Will be a LOT easier to do it this way than fanny about (technical term that) with trying to find the right connection boxes and colours................ :mrgreen:
Sonia406 wrote: Seen the album on Facebook - HOW many cars? :shock:
That isn't all of them. Here was the list so far a couple of years ago:
viewtopic.php?f=5&t=14373#p134419
Now there's a 530d & a Partner Escapade to add to the list of cars I've owned in the past 17 years. At 27 months, that 406 estate was the record holder.
I organised all my Photobucket pics a while ago into albums & I'm guessing that's what broke the links. If I get chance, I'll update the links sometime.
Sonia406
Post by Sonia406 »
My toolbox:
(Okay, I don't have a tool box at the moment, but when I show you this you'll then understand why I start a job then have to keep waiting on parts and tools................)
That dosent look abad tool set to start with, 8)
for basic jobs, sets like that are ok,
Sonia406
Post by Sonia406 »
lozz wrote:That dosent look abad tool set to start with, 8)
Nothing on a Pug is a ''basic job'' :lol:
I am kind of wishing I hadn't started playing with the electrics but I hope it's an easy fix, just waiting on the kit.
Luckily, a very kind member off of here is donating some unused tools my way (Thank you, you know who you are!)
I am also waiting on the following:
* 3/8 drive 19mm socket (No longer needed but still hasn't turned up) :shock: :twisted:
* Crimping / Cutter cable strippers, pliers
* Soldering Gun
* Solder wire (though I bought some yesterday in case the gun arrives before the wire, You know how impatient us women can be) :lol:
* Mixed colours electrical insulation tape
* 38 piece ratchet screwdriver bit set
As previously said, I won't be bothering with putting connectors on the air bag electrics, I have got so pissed off with not being able to find what I need so have given up. I asked my mechanic friend(ish) advice and he works in a garage and said they always just solder it up as it's cheaper, and made the fair point: not many people want to remove the front seat anyway. Usually if people need more space they put down the back row of seats - which, is true! I can see why Peugeot made the seats removable, but I physically can't find the 'right type' of connectors anywhere. MAYBE in the future I will find what I am looking for and do this job again, but at the moment I just need something to get the AIRBAG light to stop flashing it's sexy ass off at me. :lol:
I have all the kids this weekend so I presume, unless the gun and tape arrive today, all jobs now postponed until Monday.
I've only just seen this :oops: Sorry! I'd love to see pictures of those... That darn PhotoBucket hey :lol:
* Soldering Gun
Nothing on a CAR is a simple job. One of the reasons I let the trained professionals do the mechanical bits & bobs.
I've updated the broken Photobucket links that I could find on here. As far as the rest of the list goes, I haven't got any digital pics of any car I owned before the 306 (think I have a few traditional pics of the old Beemers, 406 & Granadas though). Everytime I sold a car since the Hilux it got a full on clean followed by photos of all angles & defects ready for advertising online.
Sonia406
Post by Sonia406 »
That is very true :(
WOW - what a long long list! I am only on my third car, putting me to shame! :shock: Mind, I am not even 28 yet...... Maybe I just get too attached to the cars :lol:
I didn't know you also had a ''family'' estate - Welcome to my 7 seater club :lol:
Best models these hey? :lol: :mrgreen:
Sonia406
Post by Sonia406 »
More help needed pretty please: :oops: :oops:
Obviously the blue wire needs soldering to a yellow wire, and the pink wire needs soldering to the other yellow wire.
My question is this: Does it matter which yellow cable gets hooked to blue / pink?
I need to be 100% sure before I do this and whilst I believe it doesn't matter which yellow I am dealing with an explosive here so need to be 100% sure..............
Any help appreciated :) - as always :)
jonsowman
Post by jonsowman »
It probably doesn't matter but I wouldn't take the risk. See if you can read the numbers on all four of the cables, then check a wiring diagram.
In future, it's best to make a note before you cut them :wink:
