D8 Cruise Control Retrofit
plod
Re: D8 Cruise Control Retrofit
Post by plod »
turning ultrasonics of alarm off??
1999 D8.5 HDi GLX - Sold :(
jonsowman
Post by jonsowman »
Yes I think it's to disable the alarm. My car's not fitted with an alarm, even though there is a blue connector to attach to that switch. I'm guessing it will do nothing at all :)
midsmike
Post by midsmike »
hi went to a scrap yard on saturday and there was a glx 2.1 in there so i unplugged the loom off the ecu and it had the pins for cruise so i had it the car never had cruise tho but i fort the loom was worth having
fuvureju
Post by fuvureju »
Did you have success in the end?
I am seriously considering of doing this but am thinking the easier option maybe to go for an after-market kit but id prefer to go for the original
I have a 406 Mk 1 (D8) 1.9DT 1996
jonsowman
Post by jonsowman »
I did not, the Lucas ECU in my car doesn't appear to have the cruise firmware running, and reflashing it is basically impossible.
The 1.9 doesn't have the same fly-by-wire system as the 2.1, so it's almost certainly not going to be possible I'm afraid!
fuvureju
Post by fuvureju »
Oki thanks
That makes my decisin to go for a goldcruise retrofit using the GC30(AP300) or GC55 (AP550) and the GC5/CM25 command stalk.
I have had a quoyte for 300-350 pounds
seems relatively easy to fit.
Do you have a wiring diagram for the cruise control...i was thinking of maybe using the Peugeot command stalk and activation switch as I have the wiring in place and i was just going to splice that comman stalk into the retofit...but i was hoping to get a clear picture of the wiring diagram (the one on the site is not so clear to read closely)
thanks
midsmike
Post by midsmike »
jonsowman wrote:I did not, the Lucas ECU in my car doesn't appear to have the cruise firmware running, and reflashing it is basically impossible.
so wat you are saying is even if i fit the loom i got from a scrap yard with the cruise pins for the ecu it wont work
jonsowman
Post by jonsowman »
It's hard to say midsmike - as far as I know nobody else has tried this, so I can't be sure that all 2.1s are like this, or I haven't done something wrong.
Bailes1992
Post by Bailes1992 »
I would think that you would have to have it plugged into PP2000 to have it activated on the ECU.
I wanted to fit cruise to my D8 1.9TD.
I explored the option of using the 3.0 V6 system and making a setup so the actuator simply pulled on the throttle arm of the fuel pump.
fuvureju
Post by fuvureju »
Quote "For reference, here's the cruise wiring diagram from a petrol D8: http://img161.imageshack.us/img161/4711 ... ncerf1.jpg"
can you repost the link so we can loom at the diagram...the one showing on the post is too blurred to read some of the detail
thanks
fuvureju
Post by fuvureju »
Oki i found what I was looking for on these 2 links
http://www.frenchcarforum.co.uk/forum/v ... hp?t=33767
this one has a link to the circuit diagram posted here before but in better quality
http://www.frenchcarforum.co.uk/forum/v ... =3&t=39257
this one goes into a discusison of the trip computer but has lots of useful info and pics!
jonsowman
Post by jonsowman »
Nice one 8)
fuvureju
Post by fuvureju »
I am getting a Goldcruise aftermarket cruise kit to fit to my D8 but was hoping to use the stalk and engament switch as my "command module" for which i needed a clear circuit diagram.
I now have 2 or 3 eahc with a slightly different numbering for the stalk! but ill work on that!
re the stalk, the follwoing wires come out of it
1 Green
2 Red
3 Blue
4 Yellow
5 Black
trying to know what eahc is.
I see that 1,2,4 come out of one side of the stalk, and 3 and 5 come out of the other
if anyone knows please post
thanks
fuvureju
Post by fuvureju »
Okay
i have finally got round to try to fit my aftermarket goldcruise cruise control
checking what wiring i have, i have the on/off switch wiring on the lower instrument panel!!! But cant find anything else
anyway here is a useful link for cruise control in particular the on/off switch wiring
http://www.peugeotforums.com/forums/mai ... %5D-28067/
Still working out how to use the peugeot original command stalk and then ill add a memory button device from goldcruise for my memory functions!
any more thoughts greatly appeciated
fuvureju
Post by fuvureju »
For the wires coming from the command stalk
3 and 5 are the wires which increase/decrease speed
1 and 2 are the live feeds from pin 2 of the engagement switch and 4 is the suspend cruise
