Yesterday in a sudden the front passenger window stuck at the middle position.I tried everything from the drivers side,the passenger side and nothing.Today I took off the doorcard to see what happen.I tried everything,even changed the electric part (of the motor where the plug goes in) with rear window and nothing.Now I took off the motor with the cable rails out and when I checked the motor is jammed.The motor shaft is jammed,and it smelled nasty.
Do someone have a motor from a passenger side pls.I took off the rails from the three bolts and if someone can do that it's better to reduce weight,because I am from Malta.
If you can help me this is my email address [email protected]
My 406 is a d8 version.
electric window motor
1.9td 1996 D8
