Coupe fans in 2.1TD?
Mountain
Post by Mountain »
Hi,
After my recent prang I need to replace a few things. My fans and the housing have been trashed. I have the double fan set up on the 2.1TD.
There are a couple complete ones on fleabay but for a coupe. I've looked on servicebox and they are almost the same. All the fan housings have the same number but the last digit varies. As for fans....well they are fans! Looks like 200w or 250w. I'd obviously have to make sure the relays were correct, but all the bolt holes are in the right place.
I'm pretty sure these would be interchangeable anyone know?
Re: Coupe fans in 2.1TD?
This RPO, that RPO, the other RPO :? It *should* fit 'cos the slam and lower panels are the same...
Mountain
Post by Mountain »
As you say, the top end has to be the same.
I might just 'make' them fit if not. They are only fans after all. The wiring is the same & if I switch the relays they should kick in the same....as long as they spin around....
Now, while the front end is off I might stick in an upgraded intercooler. Thats fooked....well bent up but still working. My brand new radiator is twisted but still working....
