Rear suspension knock
My 406 has the dreaded rear suspension 'knocking' when I go over bumps. I had assumed that this was the rear bushes, which I understand is a common fault on motors of my aprox mileage (108000). However, recently I had occasion to do a long journey with the boot fairly loaded ( about 120 kg) , and the knocking stopped, and the car almost appeared to handle better. Does this indicate anything useful, such as I should start by replacing the shocks, or something? Or does it tell me nothing? Any advice would be welcome.
I have the same problem on my 2.1 turbo. It passed the MOT with this problem and seems not to affect the handling but I agree it disappears when boot is loaded and after some research, I believe it is one of the nounting bushes on the rear suspension sub frame. I have not yet summoned up courage to try a replacement as I suspect the whole rear suspension may have to come off. But then perhaps not!
- neildavies
Had a 'thudding' noise on my old 306 D Turbo, put up with it for years, gradually getting worse, until a mechanic found it to be the rear axle bushes. Only visible when he took the exhaust off.
Don't know if the setup on a 406 is similar,
Neil
Neil
2007 307cc Sport 2.0 HDi 136
may be slightly late, but i had this problem as well, i fixed mime by replacing the rear stabilser arms. is a home job but must make aure you mark the inner part of the rod when it is removed as it sits on a cam to adjust the alignment of the rear wheel.
This can easily be scracthed onto the cam and frame of car.
Although i will say with this problem it will fail the MOT as it is something they check front and rear, so perhaps you might be right in saying its the other bushes.
Due to Recent Cutbacks, The Light at The End of The Tunnel Has Been Switched Off!
