Engine Management error light resetting
no2lurch
Post by no2lurch »
not siure which section to post this in soplease move if needed.
i have a 2001 SRi estate. whenn i bought it, the ening management light was on and the previous owner said it was due to the rear lambda sensor needing replacing.
i changed it today for a bosch genuine sensor (steered clear of the universal ones), left the battery disconnected for over an hour but when started, the car still shows the light on the dash.
how can i clear it? and if it is still on, does that mean the car will still run as if the old sensor is still there?
Current car - Ph3 1.8 306
Re: Engine Management error light resetting
Might take some "fault free" starts for the light to go out, I've heared anything from 3 to 10 mentioned. To reset the engine management you need access to a code reader.
Cannock eh? If you can make it up to stoke area some time (not this week) I can plug my lexia in, clear the codes and check for anything else
no2lurch
Post by no2lurch »
had a look on ebay for code readers but there seems to be loads.
which do i need?
no2lurch
Post by no2lurch »
where do i plug the reader into?
eoin27
The Irish 406 addict
Post by eoin27 »
There is a socket to the right of the steering wheel and its behind what looks like a series of blank switches. You can prise out the larger blank (socket cover) with a key in the gap between the smaller blank and the larger blank.
no2lurch
Post by no2lurch »
mjb wrote:Cannock eh? If you can make it up to stoke area some time (not this week) I can plug my lexia in, clear the codes and check for anything else
you in on sunday?
