ABS Ring broke
adam03031980
ABS Ring broke
Post by adam03031980 »
Hi all
posted a couple of weeks back with a brake issue anyway most has been resolved with new discs and pads as seiously unevenly worn and one of the slide bolts in the caliper was seized weith rust anyway i have notice the ABS ring as a clean snap all the way through anyone know how much they are an how to change and how easy they are to do.
jasper5
Re: ABS Ring broke
Post by jasper5 »
You have to change the CV joint complete with the ABS ring.Not sure how much they are to change, but there are a few threads about this.
Re: ABS Ring broke
I think you can get the rings separately (ebay?) but they're not cheap either. Or you could try epoxying it...
adam03031980
Re: ABS Ring broke
I did see some rings £40 each wonder if that liquid metal would do as a fix
Japster
Re: ABS Ring broke
Post by Japster »
The ring has to be metal as the abs system works by magnetic pick ups so epoxy or glue wont work for you.
Re: ABS Ring broke
Not if it's to glue the original ring back in place, the pick up won't see the glue.
Japster
Re: ABS Ring broke
Post by Japster »
If the ring has broken then there is a good chance the abs light will be on as these are shrunk fit onto the cv joints at manufacture ( heated fitted and allowed to contract ) the glue is NOT going to work for you wether the sensor see's it or not. THe abs works on gaps in the metal ring and if you have noticed all the gaps wil be the same distance apart, apart from where the ring has broken which is where the fault if any should be coming from.
Re: ABS Ring broke
Err... I knowed I saw it somewhere :?
Japster
Re: ABS Ring broke
Post by Japster »
Well blow me!! what a waste of an apprenticeship and 20 yrs on the spanners :roll:
Note to self, put tube of epoxy in the tool chest :wink:
Re: ABS Ring broke
Ah, there's your problem - you've been taught how to do stuff properly but the rest of us had to make it up as we went :P
Japster
Re: ABS Ring broke
Post by Japster »
To be honest my car has done the same thing maybe 10 times since i have bought it, but after reading this i will bow to the bodgers :P and check also the abs rings. From the feel of the pedal though i would of sworn it would be vacuum servo unit or the non return valve on the vacuum pipe. Will report back hopefully without egg all over me face :cheesy:
seismic22
Re: ABS Ring broke
Post by seismic22 »
hi, you can get the rings but you have to know the exact number of teeth on the ring to make sure you get the right one as there are a number of different sizes for the 406.
Once postage and packing has been added onto the the rings, it works out as cheap if not cheaper to buy a new CV joint. I did it a few weeks ago.
Some people say you can just push the rings over the cv joint and others say you need to warm the ring up in the oven so it expands to slide over and then contracts so its properly stuck to the joint. Either way you would have to ensure the cv joint face where the ring would sit is all cleaned up and cleared of corrosion else you either wont get the ring on or if you do and it doesnt sit flat then it could create weak points and possibly lead to premature failure.
Get a cv joint and have a nice new cv joint and abs ring for the same price as just the ring.
2002 "52" 406 Saloon HDI 110
adam03031980
Re: ABS Ring broke
Well teh gap is only about 1mm its literally a crack so was hoping it would work to hold it
adam03031980
Re: ABS Ring broke
Oh meant to say ABS light gone off now front brakes "pad and discs" were f***ed basically drivers side caliper had seized one of the slide bolts at the bottom of the caliper had locked in place causing uneven wear all teh way round it has all been changed now but just waiting to see how it goes as have only done 10 miles on new brakes so not bedded in yet.
lofty
2.2 16v
Re: ABS Ring broke
Post by lofty »
On both of my D9 hdi's they have both had the n/s/f ABS ring crack. I changed the CV joint on the 110hdi (it was a simpleknock on joint - half hours work ish from memory).
On the rapier estate, im gonna have a go at cleaning the original cv joint up, a very thin smear of chemical metal under the entire ring then holding it in place with smallish molegrips either side of the crack till it dries. If that dont work, i'll shell out another 40 quid or so for the complete joint :cry:
2001 D9 406 Hdi 90bhp Rapier Estate - Platinum Silver
1999 306 GTi-6 Weekend Toy- Astor Grey
