engine problem
keato
engine problem
Post by keato »
hi is there anyone that help me i have got a 406hdi 2000 reg . this problem only started about 5 mnths ago when driving the car it sometimes has a surg of power and drives its self is there anyone that no what could be causeing this will be realy greatful of the help thank :o
jasper5
Re: engine problem
Post by jasper5 »
I've had this problem when the oil level has been too high.
Re: engine problem
Could also be the seals in the turbo.
barryj75
Re: engine problem
Post by barryj75 »
had that problem last year kept reving upto 3000 revs had to turn off restart then be ok got rac out and he pluged in to his laptop and he said it was my high presure pump at fault
Re: engine problem
barryj75 wrote:had that problem last year kept reving upto 3000 revs had to turn off restart then be ok got rac out and he pluged in to his laptop and he said it was my high presure pump at fault
What did you do to resolve it?
barryj75
Re: engine problem
Post by barryj75 »
i found i had a leak in one of the leak off pipes and was sucking air in replaced them at the sum of £3 and its never did it again
jasper5
Re: engine problem
Post by jasper5 »
Weird :shock:
FlySpeck
Re: engine problem
Post by FlySpeck »
this used to be a common fault on lorries, and was caused by the turbo sucking in oil from worn bearings and forcing it into the diesel engine, causing the lorry to rev with no throttle input - and the strangler wouldnt cut the motor off as it was getting "fuel" from the turbine oil supply if the leak was bad enough.
Other possible causes would be dodgy injectors leaking extra fuel, as a diesel has no vacuum and the intake is always fully open, so "throttle" is achieved by increasing injector pressure and rate at the injection pump itself. Any extra fuel entering the cylinders will cause the engine to rev up.
I would check for play or wear in the throttle spindle on the pump too maybe?
2001 406 HDi 90 LX saloon with moon miles...
