The sun roof is not working on this vehicle checked for voltage at switch with ignition on today checked all fuse's all okay maybe engine has to be running for voliage at switch can any body shed sny light on this wirnig diagran !fuse location any feedback greatly appreciated
best regard's
mickey bo !!!
406 2.0 diesel 2003 eng code rhz
Re: 406 2.0 diesel 2003 eng code rhz
the sunroof mate is linked with the BSI unit and therefore you need someone with a Peugeot planet 2000 or Lexia to activate it so that it can communicate with the BSI.there is no need for the engine to be running for you to open and close the sunroof.my best bet it to reset the BSI unit itself,check the procedure of resetting here or you can remove the shunt fuse i think No 5 or 6 in the passenger fusebox for 10-15 minutes and put it back the process unlocks the bsi and reset it as well.
