hi guy
just bought pp200 now i need to know were the build code of my car is as its not stamped on the inner wing
thanx steve
were is my build code
Re: were is my buils code
I believe its on the sticker on the inside of the door post. Its the one that gives you the info on tyre pressure and what not.
Also its stamped into the passenger side strut mount in the engine bay on D9's
Re: were is my build code
on the sticker is it the number that has only 4 digits at the bottom of the label ?
thanx
thanx
"You should have a number that looks something like xxxx xx x xxxx and it's the first five numbers that are useful" - Steve Earwig
