Front Hub Nut (35mm?)
- CountryPug
Need to change my CV gaitors as one has split and throwing grease. What size is the front hub nut? 35mm? I'll need to buy a socket to remove it, biggest I have is a 32mm
Present - 95' 405 GLX TD
Previous - 01' 406 LX HDi
Re: Front Hub Nut (35mm?)
viewtopic.php?f=1&t=10419&p=92657&hilit=35mm#p92657
You might need to buy a 1/2" to 3/4 converter with the socket.
