Injector Plugs on an HDi
sirwiggum
Post by sirwiggum »
Hi,
This is going to sound like a stupid question, and the mechanics amongst you will be laughing out loud.
I wanted to have a look at the condition of the injector plugs, but I cannot seem to find them :oops:
Am I right in assuming that there should be 4 of them around the injector rail?
They should look like this:
(the 4 connectors on the left)
On a 407, google image search shows this:
I assume thats them? I can see similar going into my engine block, the connectors though are more like rubber boots and say "Siemens" on the side. I wanted to make sure they weren't the glow plug leads and I wasn't looking at the wrong thing!
Cheers
sirwiggum
Re: Injector Plugs on an HDi
Post by sirwiggum »
They're the ones above the arrows in the above pic, what i assumed were glow plug leads.
Cheers.
jasper5
Post by jasper5 »
What you are pointing to are the injector pipes (the fuel supply) the plugs (wiring connectors?) are on top of the injectors.
Unless you have a problem I would leave them alone, it's really not a good idea to mess with injectors.
The glow plugs have thin, angled connectors and have 10mm spanner size heads and are a lot thinner than the injectors.
sirwiggum
Post by sirwiggum »
Wanted to check the connectors are on correctly. Don't want to mess about with removing injectors at this stage. So long as they're getting a good electrical connection 8)
Cheers!
