Hi everyone, god knows how or why but the engine on my 2.1 td dropped down on off side which must have stressed the "newish" clutch because that is f**ked. I got towed back home but the man from AA was puzzled as to what had happened. I had drove about 8 miles and there was no indication anything was going a bollock, just lost the peddle. Anyway, the engine is fine, I supported it up and turned the key and it fired no problem.
Body work is naff, dinks and dents and a patch of paint work needs attention on the bonnet. A/C works.
6 months MOT, no tax after this month. new exhaust front pipe and back box two weeks ago.
£50, come and take it away otherwise its off to the scrap heap
Located on the A5, 2 miles from Junction 10, M42
It will need towing
2.1 td estate, spares/repair
Am I the only clown here?
Re: 2.1 td estate, spares/repair
Would have jumped at this apart from the 450 mile round trip
DAMMIT!
DAMMIT!
2.1td exec estate.
il have this if you can hold onto it till next monday
Its on the public high way, so if you can confirm that you will take it away on Monday 26th it's yours. if you can be here before 13.00 hrs even better.omega wrote:il have this if you can hold onto it till next monday
pm sent
