Heater Control Panel
keendartfan
Post by keendartfan »
I have an 1999 2.0 LX on a V plate, with fully automatic climate control/AC.
The symbols for the air direction have disappeared from the right hand side of the display. Could somebody post the order in which they appear when the direction switch is pressed. It is currently set to cabin only.
Thanks in advance.
Re: Heater Control Panel
If you press down enough times you get to: V
then successive up's get you: V> : > : V^ : ^
Hope that makes sense :?
keendartfan
Thank you.
it could be a blown bulb stopping you from seeing the display, or is the segments not lighting at all
