switched live in the engine bay?
weejimmy
Post by weejimmy »
cant seem to find any switched lives to take a feed from in the engine bay of the 406 2.1 td,
theres one on the connection from the old pump to ecu (now running bosh pump) but it stays on for 15 sec after switching the car off.
is there any proper switched lives in the engine bay at all?
2.1 td exe
Re: switched live in the engine bay?
I don't have a wiring diagram (Haynes!) to hand, but the abs ecu (on the abs pump), engine ecu and relay box (located next to the ecu) should have ignition-switched connections. You won't want to run anything heavier than a low current relay off these lines though! :shock:
Oooh hang on. The reverse switch on top of the gearbox will be ignition-switched, although I can't remember if it's handled by the ECU or not
weejimmy
Post by weejimmy »
exelent thanks ill go try these places
2.1 td exe
