Hello
I need to refill my gearbox oil after emptying accidentally.
I am unsure where then replacement gearbox oil goes ?
Can anyone help, a picture would be perfect as a im a complete novice when it comes to engines.
Any help would be much appreciated
Tony
Gearbox oil change 2.0 16v petrol
Re: Gearbox oil change 2.0 16v petrol
Take your air filter box out and on top of the gearbox you'll see a white plug. This is the reverse light switch. Remove it and pour your oil into the hole.
22mm spanner for the reverse switch and voila.
Thanks very much
Thanks very much
