KB: Connectors in footwell, crazy electrics*
Knowledge Base Articles
Locked
rapierKen
Post by rapierKen »
(apologies for loosing half the pics, I managed to save the ones on photobucket but the imageshed ones are long gone :cry: . Steve E)
It started with the "low brake fluid" warning coming up. I topped up the resevoir but this didn't fix it. I checked the connections and used the handbrake on and off method. Still not such a problem just that annoying beep! :evil:
The fuel guage started reading full all the time.
Then the fuel cap light came on. At first it glowed dimly then got brighter and stayed on.(incidently I couldn't find a reference to this in the handbook!)
After about a week the side airbag light came on along with "air bag" warning light.
Checked fuses, checked wires no joy.
Then the speedo and rev counter and temp. guages started dancing! :shock:
Tapping the brakes made them behave.
Then, with the car locked, the brake lights came on. Then went off, then glowed dimly then stayed on. At this point I pulled the fuses for the brake lights and bugger all happened. The lights stayed on. Disconnected the battery and then reconnected. Lights stayed off until I tried the brakes with the ignition on.
I removed the BSI (with the battery disconnected) and (with battery back on) turned on the ignition to find all the lights still lit up.
Must be the dash board. Out with the dash on with the soldering iron. Every pin and connection to the dials.
Put back in, no joy. Brake lights on with or without the dash board.
Removed brake light switch. (what a swine that is to remove)-lights still on!
Looked for all the earth points round the car. Got to the drivers footwell and I could hear a buzzing noise. Could it be a relay?
Took the footwell side panel off and the sill cover. Saw what looked like a wisp of smoke! :shock:
Lifted up the carpet and found a swimming pool with these underneath
Further inspection found this
and this
Using contact cleaner and good old WD I gave them a good clean. I removed the pin retaining clips and with a small file and a pick I cleaned as much rusty gunk out as I could.
After drying as much as I could and reconnecting and disconnecting all the connectors several times I turned on the ignition to find all the lights extinguished.
The "low brake fluid " warning has also disappeared!
Looking at the Haynes wiring, the fuse for the brake lights also does the dash bulbs and the passenger airbag disable. There must be a permanent live in one of the connectors(rear passenger light or boot light maybe) that was shorting and making a circuit with the brake light circuit.
I was going to bite the bullet and let an autosparky have a looksee. £45 an hour made me more determined to find the fault myself!
Reason: Pics moved to imgur
Re: low brake fluid and other warning lights
Well done that man!
Fantastic post :cheesy:
Well worth sharing with us for future reference.
It's always something simple isn't it? It's just finding it.
Silly place to put multi-pin connectors, on the floor :roll:
rapierKen
Post by rapierKen »
I think the problem was caused by the routing of my aerial wire through the door seal. I think this where the water entered. That or the jet wash.
Sorted with some bathroom sealer. :wink:
That lot could do with some waterproofing really, I'll ponder that thought! Some sort of tray for the connectors to sit in. Hmm...
rapierKen
Post by rapierKen »
teamster1975 wrote: Some sort of tray for the connectors to sit in. Hmm...
A drip tray? :lol:
If Peugeot had only put them behind the side panel they would have been dry. But hey-ho if only we had to access to foresight beforehand......... :wink:
teamster1975 wrote:That lot could do with some waterproofing really, I'll ponder that thought! Some sort of tray for the connectors to sit in. Hmm...
Wot, like a Merc? Hmm, a nice tray for the connectors to marinade in... More like wrap the damn things in self-almagamating tape!
Yeah but you'd never get the buggers apart again! Sod it, coat the whole lot in plumbers mate! :lol:
ozzie
Post by ozzie »
hello mate,your a massive help!! just bought a 406 1999 diesel and the dash went ape lately. the smell of smoke and the lights flashing and the low brake fluid warning, the rev counter and spedo counter acting up..same problems as ur post. youve saved me a small fortune and a lot of run around! thanks again mate :lol:
Locked
